Door Hinge Pins? - Ford Truck Enthusiasts Forums
Door Hinge Pins?
Old 07-26-2013, 03:34 AM
jjurva! jjurva! is offline
jjurva! is starting off with a positive reputation.
Door Hinge Pins?
1960 f100, My passenger door is sagging a little bit and you can actually feel the whole door drop when you open it. When it is open you can pick up the end of the door and there is some play in what seems like the bottom hinge. Is the pin wearing down or is it the hinge? How Do I change the pins? Also the metal that backs the hinge is near rusted away. Do the front two bolts(the ones that are most visible) do most the work or is the bolt at the back of the hinge neccesary? Seems like the front two should be able to hold most the weight.
Old 07-26-2013, 11:21 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Should be able to watch the hinge while you move the door up and down. I would not think a worn pin would not move a lot.
It sounds like bigger problems with rusted out hinge supports.
Hope I'm wrong, for your sake!
Keep us posted on what you find.
Old 07-27-2013, 03:20 AM
The hinge itself doesn't move at all so I don't think it is the rusted supports. So it has to be that either the pin is worn or the hinge itself is worn.
Old 07-27-2013, 10:59 AM
Refyred
Thats good! You can get new pins from many of the catalog suppliers. I picked up all four NOS hinges B7C-8122800-A. (just reverse the pin for right or left door) From Dennis Carpenter. That number may have changed over the years, If NumberDummy sees this he will know! But they are still out there, if you need more than the pin!
Good luck in your quest!
Old 07-27-2013, 03:38 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
B7C-8122800-A .. Right Upper & Lower Door Hinge-For use on left side, reverse hinge pin / Obsolete
1957/60 F100/1100.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
ANTIQUE AUTO SUPPLY in Arlington TX shows 1 = 817-275-2381 .. but webpage last updated 6/29/2012.
No Ford Dealer, no other obsolete parts vendor has any.
B9A-5943030-A .. Door Hinge Pin-Cut to fit / Obsolete
1957/63 F100/1100 Front Door / 1955/56 Ford Station Wagon Tailgate / 1959 Ford Ranchero & Station Wagon Tailgate.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
MILLER OBSOLETE PARTS in Binghamton NY has 9 = 607-722-5371.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 732 = 800-476-9653.
door drops on my 94 stevenjf88 1987 - 1996 F150 & Larger F-Series Trucks 1 06-01-2015 10:16 AM
Door hinge interchange 98 Explorer Mikeman Explorer, Sport Trac, Mountaineer & Aviator 0 08-18-2014 10:51 PM
Hinge replacement and door alignment... alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-06-2014 03:30 PM
Sagging Doors - hinges? StainlessSteelDream 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 07-20-2011 11:09 AM
pins & bushings or hinge?? bcaughhorn 1999 - 2003 7.3L Power Stroke Diesel 7 12-26-2010 10:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
