1965 f100 Custom Cab 4x4 352 4 spd. Help/advice - Ford Truck Enthusiasts Forums
Old 07-26-2013, 12:43 AM
Thomson65100 Thomson65100 is offline
Thomson65100 is starting off with a positive reputation.
So I have a '65 f100 that i'm trying to learn a little more about. Basically I would like to know if I have a "keeper" or a really common one. It's a 1/2 ton 4x4 custom cab with a 352 V8 under the hood, a New Process 435 4 speed tranny w/ "granny" gear, Ford rear end, also, has a PTO driven winch. Truck runs very well and starts right up every time. Any inputs would be greatly appreciated!
Carpet for 66 F100 rwrogers 1961 - 1966 F-100 & Larger F-Series Trucks 19 08-27-2014 01:36 PM
1966 F100 4x4 SWB Styleside FE352 Custom Cab mosigndude 1967 - 1972 F-100 & Larger F-Series Trucks 2 12-10-2013 12:17 AM
So, If I Was To Buy this 66 arctic y block 1961 - 1966 F-100 & Larger F-Series Trucks 46 09-11-2013 11:38 AM
352 swap to a 390 dwestcessna 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-22-2008 12:09 AM
New Process 435 transmissions Paul Therriault FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 12-25-2005 04:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
