Romeo or windsor
Apparently that would be the case according to this other thread:
https://www.ford-trucks.com/forums/8...in-number.html
The post is about how to tell the differences of some motors that are same size but made at different plants such as the 4.6ltr. Here are a few of the differences:
REP (Romeo Engine Plant) motors have 11 bolts on the left valve cover, WEP (Windsor Engine Plant) motors have 13.
Camshafts sprockets are retained differently between the two and the TDC camshaft alignments are different.
Water pump hose under the intake manifold is retained differently, REP is clamp, WEP is metal tube and nut.
REP Crankshaft main caps have 2 main cap bolts, 2 jack screws, 2 side bolts. WEP crank main caps have bolts, dowel pins, but no jackscrews.
Number of thrust washers on the last crank journal are different.
Crank main cap torque specs are different.
on
tomsolie
Modular V8 (4.6L, 5.4L)
56
03-29-2024 11:35 AM
