tcase output shaft play video - Ford Truck Enthusiasts Forums
Old 07-25-2013, 09:03 PM
woodtrucker's Avatar
woodtrucker woodtrucker is offline
woodtrucker is starting off with a positive reputation.
I made a video showing the play in the output shaft on my tcase. Can anyone tell if this looks normal before I go replacing that leaky seal? I was getting ready to do this video and shook that shaft once and and that drip at the seal dropped right in my dang eye just before I made this video...
I just don't want to go to the trouble of pulling output shaft to replace a seal only for it to go bad again because I have a bearing shot in the tcase.
Never done any of this before and don't know what would looks acceptable. Any help would be appreciated!
Old 07-25-2013, 09:12 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Go ahead and pull the drive shaft out and look at the splines on the t-case shaft, and inside the drive shaft, and see if they look worn.
Any C6 transmission experts? markeyd 1967 - 1972 F-100 & Larger F-Series Trucks 13 06-18-2015 12:56 PM
NV271F xfer case - output shaft nut size? Skiddz 1999 to 2016 Super Duty 3 04-22-2014 07:57 PM
output shaft seal leaking and output shaft housing? woodtrucker Clutch, Transmission, Differential, Axle & Transfer Case 0 07-23-2013 09:39 PM
Oil change in NP203 t'case, and lube check on axels. MAHinton Clutch, Transmission, Differential, Axle & Transfer Case 0 07-19-2003 06:49 PM
'70 C6 trans output shaft and seal petel 1967 - 1972 F-100 & Larger F-Series Trucks 6 11-15-2000 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
