Customer satisfaction program 13B08 Bad tranny hoses? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 07-25-2013, 01:57 PM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
Just got this in the mail, says uncurred rubber in the tranny hoses, and I am about to go on 1000 mile trip with TT. Trying to get it in to dealer right away, any body know what to look for?
Old 07-25-2013, 03:19 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
First I'm hearing about it, and after reading it, you're making the right decision before a long trip. Just googled it, details attached below.
Old 07-25-2013, 05:06 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
The way I read this...it applies to build dates March 21, 2013 through May 16, 2013?
My door sticker says 2/13 and the best I can tell from the window stick 2/8/13, if I'm reading it right. So...I guess I'm ok?...Phew!
Old 07-25-2013, 06:24 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Mine has a build date of 5/9 so maybe when I get back to our homebase I will have a letter. It will be time for a free oil change so they both can be handled at the same time.
Denny
Old 07-25-2013, 07:38 PM
LCT LCT is offline
LCT is starting off with a positive reputation.
Good thing I checked the forum. My truck was built in early April, no word from dealer. I will put a call in tomorrow. Thanks for the heads up.
Old 07-26-2013, 07:18 AM
LCT LCT is offline
Thanks again for heads up. Dealer advised this is such a new bulletin mailings have not quite all gone out. Appointment made. Replace hoses that are affected.
Old 07-26-2013, 07:21 AM
My dealer is going to look it over today, I checked my hoses and they seem softer than I would think but that doesn't mean they are bad, they must be checking part #'s to see if they are bad. They didn't want to look at it until Mon. but I pushed to get it looked at today so they can order parts for mon. If needed. They get .2 hr for inspection per the recall so thats easy. They had not heard about the recall so mine will be the first for them, but it really doesn't explain what to look for, how can you tell if its uncured rubber?
Old 07-26-2013, 07:48 AM
LCT LCT is offline
I do not know how they would tell uncurred vs. curred....The service rep stated they will likely order new parts and be done with it.
Old 07-26-2013, 08:08 AM
sledjunk's Avatar
sledjunk sledjunk is offline
sledjunk is starting off with a positive reputation.
Does anyone know if there is a corresponding notice in Canada?
Old 07-26-2013, 08:48 AM
Enter your vin here FordEtis home page and if it is it will show up.
Old 07-26-2013, 09:31 AM
My wife took my truck in and they said it passed inspection, there are inspection holes in the metal crimp of the hose and if the rubber is pushed out through the holes its good if not then they need replacing. My truck was built 4-9-13. When I get home I will have to check for myself because I have never heard of this before. Not sure which end of the hose they were looking at.
Old 07-26-2013, 09:56 AM
The way I'm reading it, it's the opposite, if hose is squeezed out, it's no good:
Service Action
Before delivering any of the vehicles involved in this program, dealers are to inspect the rubber hose crimp connectors on both transmission oil cooler lines. If any of the crimp connections show signs of extrusion (portion of the rubber hose "squeezed" out of the crimp), the transmission oil cooler line assembly will be replaced free of charge (parts and labor). This service must be performed on all affected vehicles at no charge to the owner.
Old 07-26-2013, 10:02 AM
Quote:
Service Action
The service writer told me the oposite over the phone I hope I just missunder stood and the mechanic did it right.
I missed that the first time I read through your link. Thanks
Old 07-26-2013, 10:08 AM
Service writers...
I'd like to think the tech/mechanic probably performed the correct check and the writer just miscommunicated it. May be worth checking it out yourself to confirm.
Old 07-26-2013, 11:09 AM
sledjunk's Avatar
Quote:
Thanks. It is there.
Tranny all of the sudden quit 78fordfan Clutch, Transmission, Differential, Axle & Transfer Case 1 08-02-2014 05:11 PM
Tranny Cooler Fittings rangerottis 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-20-2014 05:53 PM
How to flush tranny - E350 w/E40D e350guy 1968-2013 Full Size Vans 6 03-28-2014 01:45 AM
Loading without radiator FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 7 10-14-2013 01:16 PM
Upper radiator hose waldreps Ranger & B-Series 7 04-10-2006 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
