Customer satisfaction program 13B08 Bad tranny hoses? - Page 2 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 07-26-2013, 04:34 PM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
Whew. Just checked mine, built 01/13. I should be OK. thanks again for the heads up.
Sheesh, I really need to update my sig picture. I do miss my old truck, but not enough to wanna trade back
Old 07-27-2013, 07:54 PM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
I checked my hoses and 3 out of 4 the rubber does not go into the hole at all and 1 goes half way, I couldn't get a good pic of the hole but its about a 1/16" and is in the crimp, it must have to ooz out to be bad.
Old 07-30-2013, 04:29 PM
LCT LCT is offline
LCT is starting off with a positive reputation.
Truck inspected and all hoses fine. Tires rotated and out the door.
Tranny all of the sudden quit 78fordfan Clutch, Transmission, Differential, Axle & Transfer Case 1 08-02-2014 05:11 PM
Tranny Cooler Fittings rangerottis 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-20-2014 05:53 PM
How to flush tranny - E350 w/E40D e350guy 1968-2013 Full Size Vans 6 03-28-2014 01:45 AM
Loading without radiator FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 7 10-14-2013 01:16 PM
Upper radiator hose waldreps Ranger & B-Series 7 04-10-2006 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
