Give me a parts list - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-24-2013, 06:29 PM
95350PS's Avatar
95350PS 95350PS is offline
95350PS is starting off with a positive reputation.
Ok got a guy gonna do a rebuild for me. I need a full list of all parts I will need for a good solid HD rebuild 500-600hp goal.....annnnnd go!
He is going to charge me 600 for the build and give me a 2 year unlimited mile warrenty. I'd like to keep the parts bill at 2k or less.
That will keep my total bill under 3k and make me happy happy happy.
Old 07-24-2013, 07:26 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
I don't think it can be done Ben. Before my trans went, I was searching for auto rebuild parts and I was coming up close to 4k.
Old 07-24-2013, 07:27 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Like I said before, I'm not an auto trans guy, but I'm not sure you can get a 500-600 HP E4OD built for under 3k. I'd say just the parts will cost that much for that kind of build, but I may be wrong.
Old 07-24-2013, 07:28 PM
ReBilld's Avatar
You beat me to it Todd
Old 07-24-2013, 07:34 PM
tshrager's Avatar
Quote:
I was going to ask if there was an echo in here. Lol
Old 07-24-2013, 08:45 PM
95350PS's Avatar
Here's what I got so far tell me what I'm missing
T.C.-350
V.B.-250
Racer x ultimate clutch kit-519
HD driveband-18
Clutch clearance kit-25
Transfer case gasket-5
All prices are verified not guesses from the rebuild kit down is from racer tc is a diamond t from KT performance rated for 650 HP VB is either a bts or jw
Old 07-24-2013, 08:47 PM
95350PS's Avatar
I've been told by two different diesel builders I won't need shafts if I'm not going over 600hp and in all honesty I bet I don't break 500 with this truck
Old 07-24-2013, 09:02 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
It's not really the parts you put into as its the machining done to the trans
Old 07-24-2013, 09:05 PM
fordpride's Avatar
Thus is the only full kit that I know off. And after talking to Brian at BTS he said if built right it should handle 400-450 with out any machining to the trans
E4OD, 4R100 Transmission from PATC, E4OD, 4R100
Old 07-24-2013, 09:15 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
My 97 destroyed an E40D after 250,000miles. The clutches were still great believe it or not, but it destroyed the overdrive gear. The truck has mild tunes in it with mini swamps injectors. That was a $3000.00 build. My point is, it's the parts that you normally re-use in a rebuild that failed. My truck would make 400hp at the wheels if I wanted to run some hotter tunes. I would guess that a good, dependable rebuild would start with a good housing, and then fill it up with non-OEM parts if you are looking to make 500hp. Is there anybody on here that makes close to those numbers with an E40D that wasn't built by JW ir BTS?
Old 07-24-2013, 09:27 PM
tshrager's Avatar
Quote:
Darin has to be right around 400 with a guy that builds his race car trans. He used red eagle clutches, Racer X TC and VB. I believe Darin has even said its a good build, but probably one that can't get abused to much.
The bottom line is that if you want a reliable 500hp trans, there are only a few options and the cost is not cheap.
95350PS's Avatar
That seems like a lot of bologna. Lol. So your sayin no one make 500 HP with a e40d that wasn't from jw or bts I know two guys here round me who just put HD guts in their stock housings and are pushin more than 500.... is bts and jw payin you guys to say that why would there be kits out like I've found plenty of good company's have if they weren't worth anything?
Sorry don't take me as being rude
Old 07-24-2013, 09:30 PM
tshrager's Avatar
They might be pushing 500 on their trans, but for how long? How reliable is it going to be if you use that 500 all the time?
Old 07-24-2013, 09:35 PM
No body's payin' me. It's just that many of us have been around for a while, and we have a good idea what works. In my opinion, $3000.00 is a lot of money to spend for something that probably won't do what you want it to do. What kind of warranty comes with it? BTS and JW do stand behind their products. I don't have either of their transmissions in my trucks, but, none of them are making 400hp either. It's your money, and you may be fine, I don't know.
Old 07-24-2013, 09:40 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
My concern also is upgrading the planetaty gears from 4 to 6 pinion.i was looking for my dream build.i got 3k in parts real fast..but it was red eagle clutches.kolene steels.converter it would b a caddilac build.
Want to rebuild my 460, need some assistance carver94f350 1987 - 1996 F150 & Larger F-Series Trucks 33 04-17-2014 12:56 PM
ford 330 2bbl carb kit 1968grain600deere Large Truck 3 08-02-2013 08:45 PM
1991 F-150 Pinion so f'ed need whole new rear pbudzy 1987 - 1996 F150 & Larger F-Series Trucks 13 09-27-2011 07:08 PM
Yes it is a Ford F-1 afterall....Happy Fathers Day!! canadian_diesel1964 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-19-2011 11:43 AM
A Good Friday Joke King Triton General Automotive Discussion 2 04-09-2004 09:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
