89 460 low idle adjust? - Ford Truck Enthusiasts Forums
Old 07-24-2013, 06:07 PM
87diesel 87diesel is offline
87diesel is starting off with a positive reputation.
my truck has to be started off in first gear but it's real slow so i try 2nd and with enough throttle it will start but it's usually rough. its got the 460 and zf5 transmission. also when driving at low rpms it will buck like crazy. is it the idle that can be adjusted or should i run fuel injector cleaner through it?
Old 07-24-2013, 07:12 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
There is no idle adjustment. The PCM(computer) controls that function.
How long has this problem been there?
What have you already replaced?
Is the Check Engine Light on?
Have you checked for codes (regardless if you have a CEL on)?
Old 07-24-2013, 07:55 PM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
You've got something else going on, bad sensor or something. This isn't idle needing adjustment. Pull your codes, that will give a good idea where to start.
Old 07-24-2013, 07:56 PM
nothings been replaced i just deal with it. there is no engine lights or nothing. my friend has a pretty similar truck and it does the same thing. is it the injectors and can i just clean them with an additive or is it something else?
Old 07-24-2013, 07:57 PM
even starting 1st gear it can stall and kill the motor without giing it some gas.
Old 07-24-2013, 08:00 PM
RIKIL's Avatar
What do you mean starting it in gear? You need the clutch in to start, so it's not in gear. Please elaborate
Old 07-24-2013, 08:09 PM
not starting the vehicle, driving off at a stop light starting
Old 07-24-2013, 08:19 PM
rla2005's Avatar
Quote:
I have a 300 HP Mustang with a 5-speed manual transmission, I still have to give it some gas to get it rolling from a dead stop.
Perhaps I am misinterpreting your problem statement.
Old 07-24-2013, 08:37 PM
the whole issue is while the truck is in motion. the truck seems to like to buck when my foots off the throttle so i rev the engine a little to smooth it out. and say im at a stop sign and then i go to take off it'll want to stall really easy. i don't like using first gear to take off because it's really low gearing and unneccesary to me. so i tend to want to start off in second gear instead off first and it needs a little influence with the throttle so i can do so. not that stalling in second gear is the problem i just thought there is something simple that could be done to help relieve the bucking. maybe i'm just more used to my 6.9 which has a higher idle i just can't understand why it'd be that bad. when started it sounds like the idle is pretty low even to my dad. is it that the injectors could need cleaning or is that how it always is with this engine? sorry for being vague about it.
Old 07-24-2013, 08:51 PM
88LX5.0H's Avatar
88LX5.0H 88LX5.0H is offline
88LX5.0H is gaining momentum as a positive member of FTE.
So, you're taking off in second gear and are complaining that you have to give it throttle to start off?
Old 07-24-2013, 08:55 PM
no i was talking more about how it bucks so hard at low rpm's
Old 07-24-2013, 08:56 PM
just thought it should run smoother at those low rpm's
Old 07-24-2013, 08:58 PM
88LX5.0H's Avatar
How low of RPMS are we talking? Do you have a tach?
Old 07-24-2013, 09:08 PM
naw i wish i did. the previous owner put a brand new motor in it has 60k now. what's the idle supposed to be on these engines?
Old 07-24-2013, 09:13 PM
i figured it sounded in the 400rpm range but couldn't be sure
1978 Dies when idling Jcash10 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-06-2016 08:34 PM
how can I adjust idle speed to 800rpm on a 6.4l speakerfritz 1999 to 2016 Super Duty 11 07-29-2016 10:58 AM
Rough Idle issue LIL LU 1973 - 1979 F-100 & Larger F-Series Trucks 14 07-23-2016 01:25 PM
How to adjust the idle? ah1988 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 09-24-2010 10:34 PM
89 460 EFI - Idle problem 89Red Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 02-01-2004 09:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
