Transmission
I'll stick to my original statement, take it to a different shop.
The E4OD transmission in these trucks is 100% electronic controlled. The PCM is trying to tell you there is a problem. Trying to diagnose the issue without retrieving the codes is dangerous to your wallet.
Your truck could be OBD-I, which means you can run the Key On Engine Off (KOEO) tests and retrieve stored code from Continuous Memory with a paper clip. OBD-I vehicles have a diagnostic port under the hood near the driver side hood hinge. If your truck has this port, warm up the engine then do this to run the KOEO tests: Fuel Injection Technical Library » How To Run a Self-Test . Your truck will display three digit codes.
Since your truck is a 1997 model year it could also be OBD-II which requires the use of a code reader. Look under the hood for the VECI label. It will tell you which powertrain control system is is equipped with. OBD-II trucks have a diagnostic under the dashboard near the center.
The check engine light DOES NOT have to be on to read the codes!!!!!!
There can be codes set in continuous memory that do not light it up..
I'm thinking you would be better off if you read your own codes, no one around where you are seems to have a clue!!!
Here's how::: http://oldfuelinjection.com/?p=13
Yeah just the other day my F250 trans went into limp mode while my sister was driving it. No check engine light or flashing OD light. Hooked my scanner to it and it had a code for bad VSS. The check engine light doesn't always come on. You absolutely need to dump the codes yourself since the people in your neck of the woods do not understand the Ford EEC.
Well, if counting is a problem just get an EQUUS 3145 code reader at your local parts store or here::
