trailer brake controller install - Ford Truck Enthusiasts Forums
Old 07-24-2013, 01:41 PM
blue924.9's Avatar
blue924.9 blue924.9 is offline
blue924.9 is starting off with a positive reputation.
how do you go about installing a trailer brake controller on a 92 f150 4.9 e40d? i have never done it before which is why i am asking you guys. a little background, my grandpa is fixing his pulling tractor and we normally use his truck and trailer to haul my pulling tractor since his is broke, the only problem is his truck isnt big enough for both of the tractors, so i figure i got my truck and it will pull my pulling tractor just fine, but i dont have a trailer and he doesnt have a big enough bumper pull trailer for me to use, so i am looking for a trailer. i figure since i am looking at trailers i want one with trailer brakes, hence the need for a trailer brake controller. any and all help and advice is appreciated, thanks guys
Old 07-24-2013, 02:53 PM
blue924.9's Avatar
i should also say that i am going for a seven pin plug, and wish to retain my stock 4 flat plug as well so will be installing one of those plugs that has 7 round and 4 flat on it
Old 07-24-2013, 03:11 PM
blue924.9's Avatar
i should also tell you that i do not think that i have the factory plug for the trailer brake controller but i will look sometime soon just to be sure.
Old 07-24-2013, 04:49 PM
wag53's Avatar
wag53 wag53 is offline
wag53 is starting off with a positive reputation.
What make controller are you going to use? Mine is a Tekonsha. Also using a Hoppy 7 pin connector. The 7 pin plug plugs into the 4 wire truck plug. The blue wire goes forward to the controller. The black wire is aux (batt) power which I am not using. The controller comes with good instructions.
Old 07-24-2013, 04:58 PM
blue924.9's Avatar
Quote:
either the hopkins realiance or the hayes Syncronizer
Old 07-24-2013, 05:09 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Adding trailer brake wiring isn't that hard, if you can't find a ready made harness you just need a couple small spools of 12ga wire(one black and one blue) and a smaller length of white. Install a black and white length between the battery terminals and the controller(black is + and white -), and the blue goes back to the trailer connector from the controller. The battery feed should also have an inline 20a fuse near the battery.
Old 07-25-2013, 12:57 AM
77 1/2 F250 77 1/2 F250 is offline
77 1/2 F250 is starting off with a positive reputation.
All the ones I ever put in were cut and splice. The controllers came with good wiring diagrams, it was just figuring out what wire under the dash to splice into, and running the brake wire to the rear of the truck.
I don't know how big your pulling tractor is (is it the WD in your avatar?); but I totally agree with getting trailer brakes, especially if you are going to pull it with a half ton.
Robert
Old 07-25-2013, 06:54 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
My old 1992 F350 and both of my '93 Lightnings had the plug under the dash for a brake controller. All three also had the wiring and connectors at the rear of the truck for installing a 7-pin connector. I never found a factory adapter for a 7-pin so I had to splice and solder my own in.
The brake controller itself was a plug-n-play by purchasing the controller adapter for the under dash hook up.
I used an inline adapter for the tail/stop lights. It was this device that allowed me to retain the use of a 4 pin plug for towing smaller trailers.
Old 07-25-2013, 09:16 AM
blue924.9's Avatar
Robert
it is the wd in my avatar, i looked last night in fading sunlight and saw nothing. i will have to look harder this weekend when i have time when it is light out. it is in between the radio and the steering wheel correct
Old 07-25-2013, 10:36 AM
rla2005's Avatar
IIRC correctly the brake controller connector is just to the left of the center of the dash. You can see it easily from the passenger floorboard side view looking over towarss the driver side. It's a 4 wire connector. Usually attached to a small bracket.
Old 07-29-2013, 01:30 PM
blue924.9's Avatar
yes i found it!!! the only problem is that the 94 has a six wire conector with one slot being a dummy one, and the only harnesses i have found are for the six wire connector and not the 4 wire one, anyone know where i can get a 4 wire connector
Old 07-29-2013, 02:08 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Old 07-29-2013, 05:37 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I had trouble finding the adapter for the older ones and decided to just cut the plug off of the truck (GASP!!) and hard wire the brake controller harness to the truck. One less connection to go bad.
Old 07-29-2013, 08:47 PM
quaddriver quaddriver is offline
quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.
As others have said, if you have factory TT, its a splice in, if not - cake walk, you need a 30 amp breakered battery line, a 10ga line to the battery, not ground, a 10-12ga blue wire to the rear end for the brake pin on the 7 pole, and a small splice to the downstream side of BOO (brake on off switch) or in the case of 1990, a tap into the lime green with red wire in the column harness.
So easy, cavemen do it.
Old 07-30-2013, 09:39 AM
rla2005's Avatar
Quote:
Hopkins 47695:
Hopkins Plug-In Simple 47695 Ford Brake Control Adapter '92-93 W/Tow Prep : Amazon.com : Automotive Hopkins Plug-In Simple 47695 Ford Brake Control Adapter '92-93 W/Tow Prep : Amazon.com : Automotive
Looking for car trailer superrangerman2002 Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 25 06-12-2016 09:44 PM
No speaka da lingo wrvond Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 04-28-2016 11:34 AM
2001 F150 kevcarr59 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 2 03-11-2016 02:04 PM
Off Topic IH 1086 Tractor 540milotalon 1994.5 - 1997 7.3L Power Stroke Diesel 9 01-31-2016 09:49 AM
First tow and trailer brake observations tracyclifton 6.7L Power Stroke Diesel 7 07-09-2015 11:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
