Serpentine Brackets Questions - Ford Truck Enthusiasts Forums
Old 07-24-2013, 01:41 PM
orangeford's Avatar
orangeford orangeford is offline
orangeford is starting off with a positive reputation.
I have a 460 from a 76 f250 in my 79 and I am currently using v-belts and a saginaw power steering pump with a non AC bracket modified to work with AC. I would like to convert to the multi rib belt setup off of a van so I can use the same pump. I have all the 87 truck part numbers but not the number for the van AC/PS bracket for saginaw. Does anyone have this # and is it compatible with the other truck brackets.
Will the water pump pulley fit my edlebrock water pump?
I have the following numbers for a truck....
Crank Pulley E7TA-6312-AB
Water Pump Pulley E7TA-A8509-AC
Truck AC/PS Bracket E7TA19E708-CA (need correct # for van/saginaw)
Alt/smog pump bracket E7TA-10239-AB
Alt adjustment bracket E7TA-10159-BA
Idler Tensioner Pulley E7TA-6B209-FC
What year did they stop using all these parts/numbers and are they all compatible with the van PS/AC compressor bracket?
Tech: Budget 302/351 Serpentine Drive 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-30-2014 09:02 PM
Broken AC/Power Steering pump Bracket 7.5L SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 9 08-09-2014 06:39 PM
Part number request for 460 saginaw bracket orangeford 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-04-2013 05:51 PM
95 F-150 Saginaw p/s conversion: Bracket problem macintyremustang 1987 - 1996 F150 & Larger F-Series Trucks 17 05-13-2013 09:32 AM
94 F150 Saginaw upgrade with pics BCHauler 1987 - 1996 F150 & Larger F-Series Trucks 30 01-31-2013 08:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
