singing GPR - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
singing GPR
Old 07-24-2013, 02:40 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
singing GPR
I assume it means its dying or dead, but the GPR on my new truck has a high pitch hum/buzz when energized.
figuring it probably means its arcing inside, which can't be good for the GPs, i'm just going to disconnect the ground going to it for the rest of the summer and deal with it in sept/October.
any other thoughts/advice?
Old 07-24-2013, 02:51 PM
mojoman mojoman is offline
mojoman is starting off with a positive reputation.
go with the western plow relay...handles 15 volts...stock GPR is rated for 12 volts...hth
Old 07-24-2013, 03:11 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
FWIW, mine has done this since it was brand new. And it works like a champ. It's the GPR109 from NAPA.
Old 07-24-2013, 03:52 PM
well, that makes me feel better, nate. the PO did say that it was a 'new' GPR, but I took that with a grain of salt...
Old 07-24-2013, 04:05 PM
Mine does it every time. And the tone changes the longer I leave it on. People have tried to tell me it isn't making a good connection and will fail in no time, but it's been in there for 2 years and has never failed me yet.
Old 07-24-2013, 11:08 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
were talkin you can hear this puppy singing in the cab right?
Old 07-25-2013, 07:05 AM
yep - before I start the engine, obviously though :-)
Old 07-25-2013, 07:59 AM
I also have a napa one, first one smoked.
Old 07-25-2013, 08:13 AM
does your sing?
Old 07-25-2013, 09:19 AM
Oh yeah.
I just noticed the singing and thought I had another bad one.
Old 07-25-2013, 10:16 AM
weird. especially since its all DC current flowing through it. if it were AC, I wouldn't think twice about it, but what would be oscillating in a DC coil? i'm going to sound like a dork here, but from my one college electrical engineering course, in addition to the inductor of the solenoid coil, the circuit would have to have a significant capacitive or resistive (or both) element to it to create a resonance. I couldn't think of where the resistance would be, then it hit me - the GPs, themselves! they're only a few ohms, but I bet that could do it. throw in some corroded connections along the way and I bet that's it. just enough oscillation to bounce the magnet off its endstop, probably...
and the changing tone would be from the GPs changing in resistance as they heat up.
mystery solved? ...maybe.
Old 07-25-2013, 03:27 PM
I guess that could make sense. I've often wondered where the tone was coming from myself. Like you said if it were an A/C current it would make sense. Like I say though, mine has done it since day one (about 2 years ago), the last time I checked all 8 plugs were just fine, and the truck started like a champ last winter in temperatures down to the negative single digits. So..... I don't know. If it fails again I'll just get the Stancor relay and be done with it, but when I got the NAPA one, I couldn't afford to wait. Now since the truck isn't my DD I could wait for the Stancor.
GPR-109 mybigredford 1999 - 2003 7.3L Power Stroke Diesel 3 11-03-2014 10:05 PM
Sponsor that sells the Stancor GPR ? maevans 1999 - 2003 7.3L Power Stroke Diesel 5 02-21-2013 12:36 PM
gpr signal farmer ford 1994.5 - 1997 7.3L Power Stroke Diesel 4 12-02-2012 04:36 PM
GPR / AIH relays timmyboy76 1999 - 2003 7.3L Power Stroke Diesel 9 10-24-2011 08:08 PM
GPR & GPR LED question ? maevans 1999 - 2003 7.3L Power Stroke Diesel 22 12-09-2009 08:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
