Searching for rear window exterior moulding - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 07-24-2013, 11:58 AM
rhycher's Avatar
rhycher rhycher is offline
rhycher is starting off with a positive reputation.
I have a 61 Custom Cab and I can't seem to find the wrap around strip that is right below the window. Has anyone ordered this item or know where to find one? Most of the catalogs like LMC do not have this listed or maybe I just don't see it. Attaching a photo showing the piece I am describing.
Thanks! Great to have joined this forum
Old 07-24-2013, 12:19 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Searching for 1961/63 Uni Custom Cab rear window moulding
Quote:
Originally Posted by rhycher View Post
I have a 1961 Uni Custom Cab and I can't seem to find the wrap around strip that is right below the window.
Welcome to FTE
This back glass and related mouldings were only used on 1961/63 F100/250 2WD Uni Custom Cabs (body style 66B).
Uni: So called because the front of the bed is united (welded) to the back of the cab.
AFAIK, no one reproduces either of these mouldings. The specific to Uni Custom Cab only wrap-around back glass weatherstrip has been reproduced by Dennis Carpenter
Compare the Uni pic (body style 66) on the left..to the pic on the right.
Right: The back glass used on 1961/63 Uni Standard Cabs (body style 66A) and all other 1961/66 F100/1100's
Old 07-24-2013, 12:39 PM
rhycher's Avatar
I am beginning to see that is the case. I might actually remove it and paint black and use a sander to remove the paint leaving behind the black grooves. I have also thought of having it chromed as I have seen another truck have this done. Maybe I will get lucky and someone will know or have more information or even have one
Old 07-26-2013, 12:12 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
There is a 62 F250 Uni right around the corner from where I work. It's sitting up on blocks sans wheels and tires, and is in a serious state of neglect. It does however have the big back window and subsequent trim although I don't know what condition the trim is in. I keep meaning to stop by and ask them what their plans are with the truck but so far haven't find the time.
Old 07-26-2013, 07:52 AM
rhycher's Avatar
THe trim we have on there is ok but needs some TLC. When the car season comes to a close I might have it chromed. Guess I could have it powder coated silver too which would look nice.
Let me know if you hear more on that trim if you stop in there. These are the coolest trucks. We get more compliments in a single drive in this Uni than we do all season with our 23 T-Bucket.
78 F350 Fuel Sender Problem GQROD 1973 - 1979 F-100 & Larger F-Series Trucks 49 11-01-2016 05:35 PM
1991 super cab split side window custom job BalootheBronco 1987 - 1996 F150 & Larger F-Series Trucks 10 01-03-2016 08:52 PM
f100 windshield stainless trim lefty rodan 1961 - 1966 F-100 & Larger F-Series Trucks 27 12-20-2009 01:54 PM
Door panel moulding / headliner for '64 f100 Custom Cab Payner44 1961 - 1966 F-100 & Larger F-Series Trucks 37 11-21-2007 03:01 PM
Need ventwindow brackets for my 66 F100 pwillis44 1961 - 1966 F-100 & Larger F-Series Trucks 8 06-13-2007 11:33 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
