Which Is the Right PCM (Cardone? Others?) - Ford Truck Enthusiasts Forums
Old 07-24-2013, 12:27 PM
JohnLMiller's Avatar
JohnLMiller JohnLMiller is offline
JohnLMiller is starting off with a positive reputation.
I've been fighting an intermittent issue with my '95 F250 PSD for a while now (if you're interested, the ongoing thread is at http://www.ford-trucks.com/forums/12...ff-cel-on.html). I've pretty much concluded that the PCM is at fault. Now - which one do I need?
Ford says they're no longer available. (Just as well: they said they listed for over $600.) On-line sources (eBay, autocomputerexchange, etc.) have prices well upwards of $350. Several local auto parts places offer Cardone re-manufactured units for $125-$150. Unfortunately, none of the folks behind the counters are very knowledgeable: all they can do is parrot back what they have on their PC screen.
My PCM is P/N F5TF-12A650-BJF, module code DPC-202, flash rev. TEE5. According to Cardone, it looks like either their P/N 78-6749 or P/N 78-8365F might work. The former says it's for "F5TF-BJA-BJF" with calibration 5-90A; the latter says it's for module code DPC-202 with any calibration. Consistency in the specifications sure would be nice.
There is no indication anywhere on my truck (door pillars, engine compartment, glove box, etc.) about the emission calibration, so I can't follow that path.
Any thoughts on which PCM is the right one? Any thoughts on better choices?
Life shouldn't be this difficult.
Thanks.
DPC-203 All the same? whybnormal 1994.5 - 1997 7.3L Power Stroke Diesel 5 06-08-2015 10:54 AM
Selecting & Shopping For MAF/E4OD-PCM/ECU Scndsin 1987 - 1996 F150 & Larger F-Series Trucks 34 10-25-2014 03:41 PM
PCM-ICP sensor question drivembig 1994.5 - 1997 7.3L Power Stroke Diesel 17 06-17-2010 07:33 PM
Looking for a PCM drivembig 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-18-2010 12:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
