I am looking at putting an s10 frame and suspension under a 47 ford 1/2 ton truck I just bought. What year and type of s10 truck (reg. cab or ext. cab would work best? Or could anyone suggest another vehicle to use. Thank You, Brian
I'll just throw in my 2 cents measure your wheel base center of axle to center of axle and then physically check what ever model you want to use
and you might have to shorten the frame or lengthen it and the drive line to
my buddy put a blazer under his 1950 ford pickup .
