1970 ford 360 trans swap from manual to automatic
Old 07-23-2013, 12:39 AM
chawhee's Avatar
chawhee
chawhee is offline
I have a 4x4 mudbogger and I want to put a automatic just looking for advice on what to get the motor has a mild cam and headers and bigger carb
Old 07-23-2013, 12:50 AM
RichS2659's Avatar
RichS2659
RichS2659 is offline
Unless you decide you need an overdrive which would be very expensive and almost non-existant, your choice is simple: a built FE C-6 3 speed automatic.
But it also depends on what your TC is: divorced or married case?
Old 07-23-2013, 12:39 PM
chawhee's Avatar
chawhee
chawhee is offline
My transfer case is directly behind transmission how can I tell if it has a five in shaft or 8 inch
Old 07-23-2013, 07:24 PM
chawhee's Avatar
chawhee
chawhee is offline
The tc is maried
Old 07-23-2013, 09:34 PM
tpdaniels's Avatar
tpdaniels
tpdaniels is offline
I switched my 72 Highboy last winter, I used a C-6 with a divorced transfer case, you need a C-6 with a short tail-shaft, it will have a bolt on drive-shaft flange, you can use your existing short drive-shaft, you will have to have it shorten a few inches to make it work. To be able to use your current 4WD lever you need a tail-shaft from a 73 up F250 4WD C-6, it has the bolt holes cast in it for the lever to mount to plus it has the speedometer cable hole blocked off. Below is a picture of mine when I was do the switch over
Old 07-23-2013, 11:21 PM
chawhee's Avatar
chawhee
chawhee is offline
What type of shifter should I get I want a floor shifter I put some pics but not sure how to upload
Old 07-23-2013, 11:23 PM
chawhee's Avatar
chawhee
chawhee is offline
What type engine stall should I be getting
chawhee
Offroad & 4x4
07-25-2013 11:55 AM
chawhee
07-24-2013 01:08 PM
Clifford85
03-09-2009 02:21 PM
fordboy1973
04-24-2003 09:02 PM
Quick Reply: 1970 ford 360 trans swap from manual to automatic
