The Clark Swap...Has Begun - Ford Truck Enthusiasts Forums
Old 07-23-2013, 10:42 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is online now
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
I just picked up a 285V Clark out of a '76 F600.
I was originally going to get a 282 but I liked this shift pattern better.
The plan is to stick it behind the 416 in my '66 highboy so I can run 3.54's and still have a low(ish) first gear and close up the big 3 - 4 shift all in one shot.
To get the slowest speed slower I will be swapping a NP205 in.
The stock FE powered slick highboy bellhousing is on the left, the '76 F600 bellhousing is on the right. They are the exact same depth.
The top two bolt holes in the highboy bellhousing fit the top Clark holes. The bottom ones aren't even close.
The plan is to "beef" up the bell housing where the two holes need to be and then drill & tap the holes.
Here is the tag. Anyone know what all the numbers mean?
The only problem I have ran into so far is sourcing an 11" clutch disc with an 1 3/8" 10 spline hub. Any ideas on where to find one?
Old 07-23-2013, 11:24 PM
Mattrod68's Avatar
Mattrod68 Mattrod68 is offline
Mattrod68 is starting off with a positive reputation.
Old 07-24-2013, 09:21 AM
C G B's Avatar
C G B C G B is offline
C G B is starting off with a positive reputation.
Very cool man. Keep us posted.
Old 07-24-2013, 01:47 PM
Quote:
Originally Posted by Mattrod68 View Post
I hate it when I make things harder than they are. I've called 3 shops to no avail.
Old 07-24-2013, 08:10 PM
TA455HO's Avatar
TA455HO TA455HO is offline
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
If you rebuild an NP205 yourself I could recommend a
KENT MOORE TOOL J-23429 INSTALLER
Or equivalent. Trying to get the idler shaft driven in while keeping all the shims lined up is otherwise a maddening experience. Don't ask me how I know...
Old 07-24-2013, 08:57 PM
rogue40's Avatar
rogue40 rogue40 is offline
rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.
Just curious but why do you want to use the FE bellhousing? The Clark looks like it has the FE/FT block pattern, from my seat anyway.
D3TA is a Ford casting so I'm guessing 7004-EA is Fords specific part number.
Old 07-24-2013, 09:06 PM
I didn't know they had a tool. I've rebuilt two 205's without them, and that would sure be nice.
Old 07-24-2013, 09:09 PM
Quote:
If you look at the picture, it *appears* that the ears are at a different angle. That's what I thought until 20 minutes ago when I bolted the two back to back.
Now that I know that the ears are the same, I am using the F600 bellhousing.
Old 07-24-2013, 11:04 PM
TA455HO's Avatar
I wonder if the output shaft on the NP435 would work on the Clark. That's the only difference I notice. Awesome that the bellhousing would work. It sounds like you'll have a winner there.
Old 07-25-2013, 03:03 PM
Changed my mind again. The F600 bell housing holds the starter out from the fly wheel farther to allow for a bigger one (flywheel).
I plan on "cold" welding two pieces of 1/2" plate on the inside of the highboy bellhousing for the new holes to go through. Hopefully I can do it without cracking it.
Old 07-25-2013, 03:04 PM
No it won't. $189 gets me into a 1350 yoke.
Old 07-25-2013, 05:12 PM
rogue40's Avatar
How does the Clark compare, weight and size wise, to the NP?
Old 07-26-2013, 10:41 PM
It's bigger and heavier. That's about all I know.
Here's some more crappy pics. I got the plates in without cracking the housing and the holes tapped.
Old 07-27-2013, 10:08 PM
Does anybody know if the hole for the pilot bushing in a 361 is the same diameter as our FE's?
Old 07-28-2013, 09:16 PM
Anybody???
1978 F150 5.3 LM7 Swap Rossta86 Engine Swaps 44 12-27-2016 07:33 PM
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 05:20 AM
3 Projects out of the way (DONE) tasboj 1967 - 1972 F-100 & Larger F-Series Trucks 19 01-21-2013 08:28 PM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
D60 RSK Swap with Pics jchosler 1994.5 - 1997 7.3L Power Stroke Diesel 26 01-24-2011 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
