Desperate for Body Mounts
Long story short: I had a local shop make me some body mounts since they couldn't find them from the dealers. Their mounts worked great for about a month and now they are squeaking again. Since I had the luxury of a quiet Ex, I'm dying with the obnoxious noise back.
Anyone know where to get body mounts for the Excursion?
Are these parts (from an old thread) all I need? Are they ACTUALLY available in stock anywhere? Are they really that expensive? Any alternatives?
1C3Z1000145AA - SHIM (x2)
YC3Z1000155AA - BOTTOM INSULATOR (x2)
YC3Z1000154AA - UPPER INSULATOR (x2)
W705719S301 - BOLT (x2)
W705721S438 - WASHER (x2)
Thanks in advance,
-B
Thanks in advance,
-B
The washers and bolts can be picked up at any nut and bolt store like fastenall, just make sure to at least get Grade 8 at the least. If you call that company (Name escapes me) that does race mounts in poly they might be able to get you a universal "bushing" that is the same size just a tad stiffer. I assume you're somewhere in Texas?
Found it
http://www.energysuspensionparts.com...Ford+Excursion
I just moved from Tx. myself but have no college preference
http://www.energysuspensionparts.com...-Isolators.asp
I was lucky enough to buy 12 of them (for the 3 positions that are known to go first) a while back from the dealer ( hoarder .) I replaced 6 on my 02' about 80k miles ago, truck is still silent. Saving the last 6 for future on the 05'...
When you do find them I recommend replacing set in front and behind the one that's giving you problems. It will last!!
Gater180
05-23-2016 04:15 PM
