5.4 Lean code's. - Ford Truck Enthusiasts Forums
5.4 Lean code's.
Old 07-23-2013, 06:00 PM
77mud's Avatar
77mud 77mud is online now
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
5.4 Lean code's.
My mother has a 2000 Ford expedition the Radiator blew 3-4 months ago and the CEL came on. I put my scanner on it checked it and it showed a P0171 and a P0174 (bank 1&2 lean) so i cleared it and told her to let me know if it came back well the other day she came to me and said it was on (and had been since the day after I had cleared it) well i swung by a buddys shop and he put his big High dollar computer on it and said that looked like Bank 2 down stream O2 was bad, So i changed that Yesterday drove it a few miles nothing came on so i dropped her car off to her and she drove it to work and bout halfway home (aprox 40-50 miles) and it poped a code so i swung by this afternoon and pulled the code excpecting to find P0171 again but instead it was P0174..... Any Ideas why changing bank 2 O2 would clear up the Bank 1 code but not Bank 2? and any ideas what else could be causing the code? Im not off again tell next monday so She is gonna take it to my buddy's shop prolly Friday and see what he can pull then.
And Yes i changed the Driver side down stream O2.
Old 07-23-2013, 07:50 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
Usually its the up streams that sense the problem, 9 times out of 10 the o2s are fine, they are reading a vacuum leak, I would look into a air leak after the maf, which includes the intake tubing, IAc line, pcv valve and rear elbow, intake gaskets
my .02
Old 07-24-2013, 08:04 PM
77mud's Avatar
Not sure what the deal is with lights off code is gone. The o2 definitely needed changing since the wires were rubbed raw.
Old 03-08-2014, 09:05 AM
kdwellsr kdwellsr is offline
kdwellsr is starting off with a positive reputation.
I know its late after last reply but I am just now getting the P0174 code. Some abbreviations confuse me if I haven't worked there before or forgot. Can you tell me what the "IAc" is?
Old 03-09-2014, 07:06 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Idle Air Control.
Old 03-09-2014, 07:20 AM
Thank You. What things happen to indicate that the IAC is bad? Should it be cleaned or replaced if suspected bad?
Old 03-17-2014, 07:48 PM
Tasteslikeink Tasteslikeink is offline
Tasteslikeink is starting off with a positive reputation.
Spurratic idling, rough idle, rpm jumps or drops on idle.
99 f150 4.2l v6 engine light fire4915 1997 - 2003 F150 2 02-14-2016 06:36 AM
P0171 code only gibinez 1997 - 2003 F150 2 11-08-2015 08:38 PM
OBD2 Codes P0171 and P0174 Lean Bank 1 & 2 Unklebob Modular V10 (6.8l) 6 02-10-2015 07:23 AM
Need Help in a BIG Way tattooed_yoshi 1987 - 1996 F150 & Larger F-Series Trucks 5 09-06-2013 05:21 PM
P0174 and P0171 codes on V10 and other issue cherokeexj32 1968-2013 Full Size Vans 4 08-01-2013 09:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
