1990 F-250 trans swap flexplate issues - Ford Truck Enthusiasts Forums
Old 07-23-2013, 03:23 PM
mortenauthen mortenauthen is offline
mortenauthen is starting off with a positive reputation.
I have a 1990 Ford F-250 with a 7.3D and C6 automatic transmission.
I'm currently doing a transmission swap to a 4R100, with a 6-bolt pattern torque converter.
The existing flexplate has a 4-bolt pattern and is externally balanced.
Which flexplate can I use, and where can I get it?
Thanks for any help!
Old 07-23-2013, 04:41 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
welcome to FTE.
you will never get the 4R100 to work properly. you need a computer to make the trans work, and the 7.3 in the 90 is a non computer engine.
Old 07-23-2013, 05:37 PM
trackspeeder's Avatar
trackspeeder trackspeeder is offline
trackspeeder is gaining momentum as a positive member of FTE.
You need a four stud converter from an E4OD.
Old 07-23-2013, 05:43 PM
Quote:
Originally Posted by tjc transport View Post
welcome to FTE.
Hi and thanks. I'm aware of that. I have a Compu Shift II TCU so that is not an issue, the issue is the flexplate...
Old 07-23-2013, 05:45 PM
Quote:
Thanks, but the flexplate teeth are also damaged, so I will need a new flexplate anyways. The new converter has a better lockup discs, and a different stall speed. I need the flexplates.
Old 07-23-2013, 07:00 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
You could possibly redrill a 4 bolt one. I just pulled the engine out of a 7.3 IDI with an E4od and have the flywheel. PM me if you need it.
Old 07-23-2013, 09:04 PM
Quote:
Dealing with the converter is easier. If its a stock spec six stud converter it will be a little better than the four stud converter. The easy way to make a 4R work with an IDI is use the four stud converter from an E4OD. You can get these in any spec you want. $$$ is the limit.
If you want to use a six stud converter, you might get away with drilling the late stamped style flexplate.
77 351m 2wd c6 flexplate same as 400 w/ 4wd c6 the same? thuli22 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-10-2015 03:35 PM
Flexplate Question: 84f150 5.0 w/c6 swapping in 92 Mustang 5.0 blueink 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-06-2014 05:03 PM
Flexplate info??? Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 17 08-10-2011 05:22 PM
391ft flexplate to replace 390fe on C6 abc2129 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-11-2011 09:02 PM
Flexplate Needed For 6.9l 1986 F250 MECHANICTIME Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-23-2007 12:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
