my truck wont wake up... - Ford Truck Enthusiasts Forums
Old 07-23-2013, 02:03 PM
tcfd1094's Avatar
tcfd1094 tcfd1094 is offline
tcfd1094 is starting off with a positive reputation.
I resently had problems with my truck staling and replaced my cam sensor witch solved that problem then that problem returned because the wireing that whent to my cam sensor was being cut and grounding out on the crank pulley I fixed that now my most recent problem happened yesterday I parked my truck running and then I whent to start it in the morning it turns over but does not even attempt to start no smoke or anything current coads after KOEO test are P0605 internal control module ROM Error, and P1283 IPR circuit fault.
And my memory codes are P0341 can positioning sensor circuit performance, P0344 can position sensor circuit intermittent, P1212 ICP not at expected, P0236 Turbocharger boost sensor A preform, P0340 can position sensor circuit fault.I hope you guys can help im stuck right now thanks a lot guys
Old 07-23-2013, 04:41 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Try unplugging the icp and see if it starts.
Old 07-23-2013, 08:08 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Nevermind.reread.irelevant
Old 07-23-2013, 08:36 PM
95350PS's Avatar
95350PS 95350PS is offline
95350PS is starting off with a positive reputation.
Where did you get your cps from I bought one from oriellys and straight out ta the box was no good
Old 07-24-2013, 09:53 AM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Check your CPS wiring repair job. CPS uses +12 and +5 volts to operate and the +5 volts is called VREF. VREF is what powers most the sensors in the truck and most of yours are indicating bad. Quite possible you miss wired and VREF (5 volts) is shorting out.
Old 07-24-2013, 10:58 PM
tcfd1094's Avatar
thanks for the help it ended up being wires going to the ipr i unpluged them clead and plugged them back in and it started right up i cleared all the coads and all is well excpet the P0605 icm ROM error code came back instently and refuses to clear any one know what this code meens it runs and drives fine buy the way my water pump went today im not a happy camper lol
Help needed Jonathan Day 2004 - 2008 F150 8 10-03-2016 04:06 PM
5.4 Revving issue and im stumped. F250Oldie Modular V8 (4.6L, 5.4L) 1 07-20-2016 03:28 AM
5.4 Revving issue and im stumped. F250Oldie 1999 to 2016 Super Duty 0 07-15-2016 09:17 PM
06 F150 5.4 3V won't start Jiffy_1 2004 - 2008 F150 12 10-12-2014 02:23 PM
Ford OBDII trouble codes 01silvergt 1997-2006 Expedition & Navigator 2 07-13-2005 02:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
