Massive breakdown on vacation - Ford Truck Enthusiasts Forums
Old 07-23-2013, 01:17 PM
hoytfan99 hoytfan99 is offline
hoytfan99 is starting off with a positive reputation.
So my father in law and I both have 05 6.0's mine is set up with gauges his isin't. His broke down 3 hours into the trip in Dover Del. blew white smoke, lost 2 plus gallons of water, and had no power. He filled it with water let it cool down and tryed to start it up only to hydro lock the engine. Towed to Winner ford in dover and after 1 day of looking at it they say he needs a new engine. Bull--it on them, it sounds like egr cooler went but he couldn't have hurt that much trying to start the engine locked could he? Only code it pulled was a 0238. What do you guys think.
Old 07-23-2013, 02:23 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
It could have bent rods, push rods, punched a hole in a piston and or damaged a crank. All or none of the mentioned items. Hydrolock is bad ju-ju for these engines. I would however get a 2nd op. on a diagnosis like this unless I was comfortable with the shop.
Old 07-23-2013, 02:37 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
I'd get another opinion too.
If there isn't visual evidence of catastrophic failure I'd say that it needed to at least have the glowplugs removed and see if it's not a coolant hydrolock from an EGR cooler failure. New engine is kind of extreme for this "common" problem.
Old 07-23-2013, 03:08 PM
big inch big inch is offline
big inch has a good reputation on FTE.big inch has a good reputation on FTE.big inch has a good reputation on FTE.
I have seen dozens of 6.0's hydrolocked with coolant and fuel, and I don't recall ever having one even bend a rod. The bottom end is pretty stout in these things.
If it were mine, it would get a BPD egr cooler, Ford oil cooler, coolant flush and an oil and filter change. And if funds allowed, new STC fitting, standpipe and dummy plugs.
Old 07-23-2013, 03:11 PM
69cj's Avatar
I definitely wouldn't spend money on that stuff till I knew for sure the correct diagnosis.
Old 07-23-2013, 03:18 PM
Well let's see...white smoke, 2 gallons of coolant gone and hydrolocked engine. What does that sound like to you?
It sounds like to me that they ended up at a Ford dealer who probably doesn't have an experienced diesel tech. Which unfortunately is becoming all too common these days.
Old 07-23-2013, 04:12 PM
raptor131's Avatar
raptor131 raptor131 is offline
raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.
I would venture to guess it was a egr cooler let go, and didn't need a new engine till they had it for the day. It might need one now
Old 07-23-2013, 05:29 PM
69cj's Avatar
Not arguing that fact, just saying till the engine is apart and damage assessed I would not prematurely spend the money on those parts. They are not cheap. I've been bit before jumping to conclusions. However if it ever does happen to you feel free to spend your money as you see fit.
Old 07-23-2013, 05:32 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Did it melt the oil filter stand pipe?
Old 07-23-2013, 07:40 PM
their were no leaks anywhere under the truck, even from the weep holes in the exhaust system, found out today they dont have a diesel certified tech. on staff so it's gettin towed home to my dealer.
Old 07-23-2013, 07:48 PM
Remove the oil filter cap and filter and see if the spiral plastic pipe that goes through the center of the filter element is still there. If it's gone, it melted and is plugging up oil passages through out the engine...it's toast. If it's still there there may be hope for repair.
Old 07-23-2013, 08:20 PM
69cj's Avatar
Quote:
Bingo, hope they didn't cause more damage than originally caused. Hopefully it's going to someone that can distinguish the dif. from the original damage and any secondary caused damage.
Old 07-23-2013, 10:44 PM
raptor131's Avatar
Quote:
This is my fear. I hope they didn't just keep cranking it ,or try to with all that coolant in the cylinder
Old 07-23-2013, 11:41 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Guess you gave Dad in Law the Gauges Talk LOL
Old 07-24-2013, 10:37 AM
only tryed to crank it one time and the belts only moved about 3/4 of an inch, and yes now he knows why I have them. When I gett back to the truck I'll check the oil filter out.
Finally took it in for inspection pbsdaddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 05-06-2015 08:15 PM
2000 Ranger 3.0L Running Rough, shuddering at stops alnbrgr2014 Ranger & B-Series 4 03-23-2015 10:10 PM
1990 302 back fire need help Danny Weimer 1978 - 1996 Big Bronco 13 08-06-2014 11:57 AM
63 F100 Brakes and Info mrpesas 1961 - 1966 F-100 & Larger F-Series Trucks 8 06-03-2014 10:46 AM
Ford F250 7.3 liter diesel - serious starting problem john m kirby 1999 - 2003 7.3L Power Stroke Diesel 20 11-22-2011 11:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
