What Kind of MPG to Expect - Ford Truck Enthusiasts Forums
Old 07-23-2013, 10:28 AM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Hey guys. Im looking to upgrade the ol PSD in the very near future. Some upgrades Im thinking about doing are some Rosewood Stage II (or possibly III) injectors, upgrade to a D66 turbo, put a 99-03 intake on it (supposedly better) along with my 6637, some sort of tuner (liking Riffraffs) maybe some up-pipes and hook it all up to my 3" DP to 4" exhaust (of course the trannys next)
I don't think this stuff is too radical but Id still like to stay somewhere in the neighborhood of 16+ mpgs. The only thing that scared me was my brother drove a Cummins pulling truck as his DD. Huge injectors, massive turbo, etc etc and he claimed 11 mpgs... That's ridiculous! A 460 can do better than that! (At half the power)
Old 07-23-2013, 06:43 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Your mileage won't change much with upgrades, unless you can't keep your foot out of it.
Old 07-23-2013, 06:54 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
I get 12 with my truck. But it is heavier than stock.
Old 07-23-2013, 07:17 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
I'm getting 15/16 mixed use average with my mods in my sig.
A couple of things about the mods you listed. What are your HP goals? Stage 2's and definitely 3's are a bad idea for the D66. It flat out can't keep up. Do you tow? What do you want out of your truck and we can point you in the right direction.
Old 07-24-2013, 09:49 AM
Ahh someone asking the right questions lol. Im kinda shooting in the dark on this whole deal.
Here we go: This will be mostly a DD. I have a slide-in camper (one that slides in the back of the truck) that I use occasionally. My father-in-law has a race car that I offer to tow for him a few times a year. And mostly, I want something that is completely reliable but has a good kick in the pants! I have no desire to race or take it to the pulls whatsoever.
If I got 400 hp, I would be blown away. That's plenty for what I want
I notice your sig says stage IIs but no turbo upgrade? Can our stockers handle stage IIs?
Old 07-24-2013, 07:17 PM
tshrager's Avatar
They can, you just have to keep the boost at or below 30 psi. A lot will depend on budget as well. Some nice stage 1's, D66, intercooler and e fuel can do wonders. Could probably get away without upgrading your HPOP as well. This can be done relatively cheap. If you're looking for reliable 400hp, then I'd be looking at 180/80's (or somewhere in that range) s366 with full mount kit, intercooler, e fuel, T500 HPOP and some good tunes. That should be a nice setup and easily knock on the door of 400hp. You would be right in the range for needing studs, springs and pushrods though. That's the problem with going for power. Bigger power = more supporting mods = more money. What are you running for a trans?
Old 07-24-2013, 11:07 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
Every truck is different too, My ole girl loves 2-stroke
Old 07-25-2013, 11:10 AM
Im going to take a different approach after chatting with Mike (aka fordpride)
Stage I Injectors
S366
Good Tuner
Intercooler
Head Studs
Springs and Pushrods
And of course... do something with the tranny
I may try to stick with my stock turbo for now unless its going to be a huge PITA to put in while the engines in the truck. Then it may be worth the extra $1200+ lol
And also, Iv heard of E-Fuel mentioned a few times. What is that?
Old 07-25-2013, 11:59 AM
tshrager's Avatar
Stage I Injectors
S366
Good Tuner
Intercooler
Head Studs
Electric Fuel.
Sounds like a great setup.
Old 07-25-2013, 02:30 PM
So is it just an electric fuel pump or is it a whole fuel system upgrade?
Old 07-25-2013, 05:04 PM
It's a whole system upgrade, and is necessary if you do the S366. The turbo uses the plunger hole in the block for the oil return.
Why are we discussing a build in two threads??
Old 07-25-2013, 05:17 PM
They both kind of got out of hand lol. If it helps, each is teaching me something different lol. I think Ill just start a build thread and go from there lol
Old 07-25-2013, 05:28 PM
Hey guys. I have 2 nearly identical threads going on right now so I decided to start a build thread! We can continue this conversation over there. I want to say thanks to everyone who has responded!!
http://www.ford-trucks.com/forums/12...l#post13373462
6.9l in my 460 truck, ford gods please help me. glovemeister 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 04-05-2014 04:48 PM
Post EGR delete, SCT tuner, ARP studs Review/q's rayrocksweet 6.0L Power Stroke Diesel 10 03-08-2014 10:44 AM
Best Products For My 7.3 El Camino Man 1994.5 - 1997 7.3L Power Stroke Diesel 31 06-02-2013 10:46 AM
early 99 / late 99 issues 7-point-3 1999 to 2016 Super Duty 1 02-20-2013 06:35 PM
Axle Strength (What can hold up to the mighty Cummins?) EasternAggie 1987 - 1996 F150 & Larger F-Series Trucks 27 02-13-2011 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
