4 x 4 Ball joints
Old 07-22-2013, 10:21 PM
bigTEE56's Avatar
bigTEE56
bigTEE56 is offline
4 x 4 Ball joints
I have a 94 F150 4x4 with IFS. The factory manual says you need to pull the front differential in order to replace the ball joints. I'm hoping that's not the case. I am going to be pulling the spindles and need advice on how to break them free. They're not rusted just can't get them off and really don't want to use a torch to heat the steering knuckle up.
If anyone has experience doing this project I'd appreciate any tips or advise.
Thanks in advance!
Old 07-22-2013, 10:32 PM
f1504x4driver's Avatar
f1504x4driver
f1504x4driver is offline
Proud Pirate
You do not have to remove the entire IFS. You will have to remove the hub, spindle and axle shafts, then rent or buy the proper tool to remove the ball joints. There is a good video on you tube showing how it is done and some great write ups on here about rebuilding the front end. I think Encho has one.
Old 07-22-2013, 10:36 PM
OldGrayFord's Avatar
OldGrayFord
OldGrayFord is offline
It's a big enough job, I'd consider replacing everything you can while,it's apart. U joints etc. that away you don't have to do it again
Old 07-22-2013, 10:41 PM
f1504x4driver
Proud Pirate
I totally agree with OldGrayFord. Do it all while you have it apart.
Old 07-22-2013, 11:06 PM
bigTEE56's Avatar
bigTEE56
bigTEE56 is offline
Thanks Guy! I watched a video on the front end. The one I watched shows after you get the spindle off, the axles pull right out??? So it's not like the rear diff. where there is C clips are holding the axles?
That would be great if it means that's all I have to do. I just need to buy the U joints, boot for the spline shaft on the passenger side. Already have spindle bearings, seals, ball joints. I'll clean the case of dirt and grime before pulling axles, can I do the Differential seals as well?
I just did the bearings and wanted to see how involved it was and the factory manual said you had to pull the diff. Didn't make sense, but I've found that sometimes the factory likes to do things the hard way.
I'm fortunate to have all the tools. I just really didn't want to open up the differential if I could avoid it. Still recovering from major back surgery and with out a lift I didn't want to be on the loosing end of a wrestling match with the differential.
Old 07-23-2013, 01:04 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
If I remember correctly from taking mine apart, there's 1. On the passenger side.
Old 07-23-2013, 06:11 AM
bashby's Avatar
bashby
bashby is offline
The pass side has a slip joint in the axle. Remove a clamp from the rubber boot and it will slide apart, leaving the inner u joint attached to the diff. The inner ujoint rarely goes bad, so I would not worry about replacing it. When you put it back together, you should line the inner and outer joints up to avoid vibration when hubs are locked. I just put a zip tie on the boot to replace the factory clamp.
Old 07-23-2013, 06:46 AM
Daniel5.0's Avatar
Daniel5.0
Daniel5.0 is offline
Removing the spindle is a real treat. I used about half a can of PB Blaster over a week, made a puller, and still had to heat it. Even then it certainly didn't fall out.
I've seen pullers available for purchase that are based around a slide hammer. Instead, I made mine so that it pushes against the spindle mounting nuts, and is tightened with the large spindle nut on the outside. It worked quite well.
Old 07-23-2013, 08:04 AM
IowanStraight6's Avatar
IowanStraight6
IowanStraight6 is offline
I just recently did a front end rebuild on my 96 every seal ujoint and even pivot bushings where replaced I just haven't had the time to do a write up. But the tool to find for those spindles is the special threaded attachment to screw on the end of the spindle that attaches to a slide hammer about five knocks and popeasy as you can get...
HotrodSmurf
21
02-09-2016 09:26 AM
bmxerbrett
01-17-2015 03:39 PM
82airborne82
04-09-2010 06:37 AM
Ryanpb85
1999 to 2016 Super Duty
03-09-2006 06:26 AM
qwk twk
05-05-2003 11:51 AM
Quick Reply: 4 x 4 Ball joints
