striker bolt removal / door panel rattle - Ford Truck Enthusiasts Forums
Old 06-12-2003, 04:14 PM
joex joex is offline
joex is starting off with a positive reputation.
Hey All -
First time poster here. Got a '93 EB 302 115k owned since new, having to do some things to. Couple questions:
Striker bolts - looks like they just twist out with torx T50, but my question is, is the inside connector welded into the backside of the door jam, or loose? (when bolt finally comes out, nut falls down and out of site, or stays in place?) Same question/answer for tailgate strikers.(?)
Door panels - I took both off the same day without aid of manual, and ended up breaking off the little tab in the center that holds it snug. Now both rattle like crazy, and is driving me insane. Anyone else make this mistake, and how have you dealt w/it? Can't find replacement panels for '93 EB at any price, not that I would pay $400 anyway.
Thanks in advance for your input.
Best -
Joe Horn
Old 06-12-2003, 09:45 PM
justshootme84 justshootme84 is offline
justshootme84 is starting off with a positive reputation.
The door and tailgate strikers can be removed, and the insert will stay in place. It is a little loose for adjustment, but won't fall down out of sight!
As for the door panels rattling, I have the same problem. Thought about a small dab of epoxy cement to hold them to the door. Just enough to hold the middle of the panel so it won't rattle.
Old 06-13-2003, 07:54 AM
storehoz storehoz is offline
storehoz is starting off with a positive reputation.
Lightbulb striker bolt removal / door panel rattle
My '88 had the same issue. I took some heat/sound insulation material and covered the mounting side of the panel in some stategic places. My idea was to have the insulation material stick out just a little futher than the surfaces that actually make contact around the nylon push in trim retainers and the door itself (I don't know the official name for those retainers). About an 1/8" to a 1/4" seemed to work well and didn't make the panel bulge out from trying to compress the insulation. The insulation added just enough resistance to keep the door panel from vibrating and causing the rattle. Also it has cut down on some of the road noise. It was a cheap fix and I'm putting this behind each large trim panel as I have reason to remove them while working on this vehicle.
Old 06-13-2003, 02:32 PM
Great news, thanks. That's what I'd hoped for and expected, but ya never know, right? And if it *didn't* work that way, well, it'd be a pain.
Quote:
Originally posted by storehoz [/i]
[B]My '88 had the same issue. I took some heat/sound insulation material and covered the mounting side of the panel in some stategic places. My idea was to have the insulation material stick out just a little futher than the surfaces that actually make contact around the nylon push in trim retainers and the door itself (I don't know the official name for those retainers). About an 1/8" to a 1/4" seemed to work well and didn't make the panel bulge out from trying to compress the insulation. The insulation added just enough resistance to keep the door panel from vibrating and causing the rattle. Also it has cut down on some of the road noise. It was a cheap fix and I'm putting this behind each large trim panel as I have reason to remove them while working on this vehicle.
Cool. I hadn't thought of that. Did you use the regular strips/rolls of unsulation like you'd ***** around windows in the house, or some kind of sheet insulation? I'm thinking now that maybe just the 1"wide X 1/8" thick stuff I already have just might work. I was also considering that sticky, black, stuff I find in the guts of every car/truck I've ever seen. (butyl adheisive or something like that) But it's so dang nasty, I'd rather not.
Hey, guys, thanks! You've given me a good excuse to spend some time in the garage this weekend.
Best -
Joe Horn
Old 06-13-2003, 11:21 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
Next time, look it up here or in a Haynes manual before you break something.
Old 06-14-2003, 11:16 AM
AlabamaBronco's Avatar
AlabamaBronco AlabamaBronco is offline
AlabamaBronco is starting off with a positive reputation.
Make sure that the nylon bushing is still on the striher bolt. If its gone you can get replacements at just about any auto parts store. You can adjust the door without them, but it wont be right.
Old 06-16-2003, 05:25 PM
Wakeboarder141's Avatar
Wakeboarder141 Wakeboarder141 is offline
Wakeboarder141 is starting off with a positive reputation.
Are the striker bolts on the tailgate supposed to hav e those nylon bushings or just the ones on for the doors?
Old 06-17-2003, 04:54 PM
Quote:
Yes, tailgate strikers have the bushings too. Slightly shorter than the door bushings though. I had a couple extra door bushings and dremeled them off to the right length - works great. I got the door and tailgate strikers/bushings replaced and adjusted, along with new tailgate cables installed last night in about an hour. Makes a world of difference, and figured out a lot of the rattle I heard coming from the pass. side wasn't the panel, but the door hinge.
Thanks again for the tips and info, and thanks especially for the online manual site. I had no idea it was available.
Best -
Joe Horn
Old 06-17-2003, 09:07 PM
What exactly would I be looking forward to see if I still have these bushings or not? Are they fairly obvious?
Old 06-17-2003, 10:19 PM
bigric's Avatar
bigric bigric is offline
bigric is starting off with a positive reputation.
The nylon bushing will actually wrap all the way around the metal striker bolt. If you don't see any plastic-looking stuff, your bushing is gone.
With heat and age, they get dry, crack, and fall off.
Old 06-17-2003, 10:21 PM
where is a good place to get replacements?
Old 06-18-2003, 11:40 PM
steve83's Avatar
Junkyards.
Old 06-23-2003, 12:27 AM
Guess I have to correct my previous post on the door strikers!!! When I removed them from my 88 parts Bronco, the retainer/nut stayed in place. When I unbolted the pass.-side striker today on my 84 Bronco, the retainer fell down!!!
I had to loosen and pull back the rear inner panel, and retrieve the retainer from the bottom of the door! The good news is that there's a hole about striker-level just big enough to get a pair of pliers thru, and fasten the new striker while holding the retainer.
I got new strikers from an aftermarket supplier, for a 78-79 Bronco, with the plastic bushings. The ones listed for 80-86 have a metal clip over the bushing, but mine are the older style. GO figure???
Old 06-23-2003, 01:54 PM
Yeah, that's exactly what prompted my original post. Happened to me in another life on a '73 Peterbilt. Large backing nut fell into an unaccessable inside pocket. Got the panel off to get another nut on the striker, but the lost nut rattled like a SOB from then on.
My nuts, so to speak, stayed where they were supposed to stay, and I fugure most Bronco would. Have you had body work on that door?
Best -
Joe Horn
Old 06-23-2003, 07:16 PM
AlM's Avatar
AlM AlM is offline
AlM is starting off with a positive reputation.
yo,
Aside from the dealer, or the yard;
Motormite (also Help..ya kno?..those parts racks at most auto supply stores);
Item Number: 38426
Description: Door Striker Bolts AND Kits
Brand: MOTORMITE
Application: Includes bolt and bushing. Fits full-size Bronco 1996-83
Detail Buyers Guide Attributes:
Thread size : M10-1.50
http://www.motormitedormancatalog.co...es/5038426.jpg
Item Number: 38445
Brand: MOTORMITE
Application: Fits Ford/Mercury. Taurus/Sable, Tempo/Topaz, Escort/Lynx, Aerostar, Ranger, Bro
http://www.motormitedormancatalog.co...es/5038445.jpg
You can't fix stupid! Door assistance needed! overlandexpress 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-03-2015 02:34 PM
What is the proper way to adjust F150 door latch/striker? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 20 02-10-2015 12:30 PM
Door striker ? V10man 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-02-2012 05:33 PM
Removing the Door Latch Strikers (in the door jams) on my 93 Explorer wickware Explorer, Sport Trac, Mountaineer & Aviator 11 02-04-2005 08:30 PM
striker bolt bushings dhepler 1978 - 1996 Big Bronco 6 10-12-2004 09:51 AM
Tags
38426, 38445, 79, bolt, bronco, door, explorer, f150, ford, motormite, rattle, remove, size, striker, torx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
