Automotive Wiring Info
The haynes manuels for broncos give very nice wiring diagrams.
For aftermarket fog, or driving lamps, its basically a battery feed to switch inside cab, then to lamps, then ground. When you start messing with relays,it can get complicated to some people, I do it for a living though.
What do you have in mind?
I eventually want to hook up fog lights, bronco needs a radio and speakers, and later on lights on a bar on the roof. My problem is that I have done so little automotive wiring that Im a little nervous about making a costly mistake. I have leraned that I can do good with a manual. I just know very little about the basics.
Here is automotive electrical 101.
http://autorepair.about.com/gi/dynam...com%2Fbasae%2F
Here are three articles that deal with wiring headlight with relays but you can adapt them to fog lights/driving lights
http://lighting.mbz.org/tech/relays/relays.html
http://faq.auto.light.tripod.com/headlamp-harness.html
http://pwp.clearsource.net/dsigns/james/headlights.htm
