Will no start/run - Ford Truck Enthusiasts Forums
Will no start/run
Old 07-22-2013, 05:31 PM
daddy23 daddy23 is offline
daddy23 is starting off with a positive reputation.
Unhappy Will no start/run
2004 F350, 6.0 Was having problems maintaining power when coming to a stop, or letting up to turn. I replaced both the fuel filter and water/fuel seperator filter. Still did not run properly. So I pulled the water/fuel seperator to check for crud. No crud found. Now the truck will not start at all. Truck shows full on the fuel gauge. I have poured diesel into the filter well slowly to remove air in line. I have cycled engine five times before starting. Still nothing. I removed fuel lines and cycled, fuel comes out slowly, and just a little bit, shouldn't it come pouring out?
HELP!!!!!
Old 07-22-2013, 05:46 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
moved to the 6.0 forum
Old 07-22-2013, 06:26 PM
dannyboy950 dannyboy950 is offline
dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.
You may have a fuel pump going out. There is a pressure test port at the bottom front of the filter houseing, requiers a 12mm adapter if iI remember correctly.
You should have 50 psi minimum.
Old 07-22-2013, 06:38 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
HELP!!!!!
Sounds like a fuel pump to me also. With the top off the secondary fuel filter housing it should fill VERY quickly--maybe 2 or 3 seconds max.
Old 07-22-2013, 07:53 PM
Thx- So, to remove the box, or drop the tank. I'm thinkin the box will be a lot easier.
Old 07-22-2013, 08:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Fuel pump is a combination unit. HFCM (Horizontal Fuel Conditioning Module) Same part the water separator filter goes in on frame rail under truck. No pump in the tank.
Old 07-22-2013, 08:50 PM
Quote:
Sweet, that sounds a lot easier. THX
Old 07-22-2013, 09:09 PM
No problem, welcome to FTE!
Old 07-22-2013, 09:50 PM
Z-MAN's Avatar
Z-MAN Z-MAN is offline
Z-MAN is starting off with a positive reputation.
Check hpop psi minimum to start truck is 500psi. Don't ask me how I know is it cranking but not firing? Mine just gave up the ghost aT 137k
Water in Fuel (nothing comes out) & Wrench Symbol Tawn 6.4L Power Stroke Diesel 28 05-11-2014 03:02 PM
Water in the Fuel Line? 04KingRanch 6.0L Power Stroke Diesel 22 03-30-2013 12:56 AM
Update on Water-in-Fuel indicator light TXHillCountry 1999 to 2016 Super Duty 6 10-04-2010 10:39 AM
water/fuel seperator light johnperdeye 6.0L Power Stroke Diesel 14 02-25-2008 12:14 PM
Water/Fuel Seperator on F350SD dnc1963 1999 - 2003 7.3L Power Stroke Diesel 4 01-13-2008 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
