crank shaft pulley
Old 07-22-2013, 12:40 PM
1950F2's Avatar
1950F2
1950F2 is offline
crank shaft pulley
I just got my motor back from rebuild and they lost the key and washer and bolt that holds the pulley onto the crank shaft.
Where can I get key, washer, bolt??
Also can the "dust seal" be put on after the flywheel is bolted in place?
I just need the gasket part not aluminum part, it is on.
Old 07-22-2013, 12:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The shop that did mine lost the key too. NAPA has it, 1/4" x 1".
I'd press the shop to come up with the bolt and washer, hard to find in equal quality.
The bolt is a 9/16-18 x 1-3/4", at least Grade 8. P/N C1TE-6A340-B. Available here: http://www.nospartsltd.com/product-p/c1te6a340b.htm
Washer is 1.76" OD, .58" ID, .31 - .34" thick, p/n 372757-S (XX200).
Old 07-23-2013, 09:10 AM
1950F2's Avatar
1950F2
1950F2 is offline
Thanks ALBUQ F-1 for the size of the bolt, Got that coming from our local Fastenal store, I can get washer made now I know size.
Thanks,
jack odom
08-17-2013 12:21 AM
Payner44
02-15-2008 06:35 AM
MBBFord
06-26-2006 05:24 PM
FordPUs
12-14-2005 02:32 PM
Quick Reply: crank shaft pulley
