351C 4V Blue Thunder Intake - Ford Truck Enthusiasts Forums
All Other Items for Sale All other items (non Ford Truck related) for sale. Tools for the garage, brake pads for your 66 Mustang and your beer fridge go here.
Old 07-22-2013, 10:39 AM
jredline1984's Avatar
jredline1984 jredline1984 is offline
jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.jredline1984 has a spectacular reputation.
Hi Guys, I have a new in the box blue thunder intake that I am looking to trade for a Weiand Tunnel ram. I'm switching to fuel injection and want to modify the tunnel ram for a throttle body and injectors.
I would also sell the blue thunder outright for $380+ ride.
Let me know if you have anything that will work.
Thanks!
From Mustangs Unlimited:
INTAKE MANIFOLD DUAL PLANE 351C-4V (BLUE THUNDER)
Blue Thunder Intake Manifold, Aluminum High Rise Dual Plane for 1970-1974 Ford 351C-4V.
Possibly the best performing 351C dual plane intake available, this dual plane runs strong from off-idle all the way to 6,800 rpm! Equipped with a heat riser for street use, it also fits under all stock Mustang & Cougar hoods with stock air cleaners. Accepts 4150-style Holley & other squarebore carburetors.
Height to front of carb pad: 4-7/16" & rear of carb pad: 5-3/8"
~Corey
Old 01-10-2014, 11:10 PM
eklemz eklemz is offline
eklemz is starting off with a positive reputation.
This still available?
Corey,
If this is still in your hands - its mine. Let me know!
-Ed
4BBL on a 390 Opinion Time Order and Chaos FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 05-18-2016 07:56 AM
Chris' 2wd f150 460 build thread Chris Guthro 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 116 08-01-2013 11:08 AM
Crossmember williebones 1957 - 1960 F100 & Larger F-Series Trucks 2 04-26-2013 08:08 PM
Best 390 Intake for truck FossenRacing FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 12-04-2011 07:24 PM
1979 F150 NP205 Mounting jredline1984 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-08-2011 07:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
