1972 F-250 Engine ID - Ford Truck Enthusiasts Forums
Old 07-21-2013, 10:06 PM
Maelstorm Maelstorm is offline
Maelstorm is starting off with a positive reputation.
Myself and some family members are getting ready to do a tear down and rebuild of the engine in my brother's 1972 F-250 pickup truck. We are having some problems identifying the engine displacement. I took a caliper and mic'd out the bore to be 4.050". I got the stroke to be 3.516". According to my calculations, this puts the engine at 360ci. I did the following formula to get that result:
pi * (4.05/2)^2 * 3.516 * 8 = 360.71
Is this correct or should I be looking at something else?
We have the heads pulled and the block is out of the truck on a stand. The numbers on the block where the casting number should be says "49 DIF". There are other miscellaneous numbers but no casting number that I can see. On the back of the engine, it has a 352 stamped and overlaid in yellow paint. I figure it's a FE block since we had to pull the valve covers and the intake manifold off before we could pull the heads off even though there is no mirror image 501 on the front. The heads are at a machine shop getting new exhaust valve seats installed since the original valve seats are gone. There was also something like 5 burnt valves as well. The pistons are black but they seem to be is good shape, and we can't feel any ridge in the bore. The casting numbers on the heads was something like a C8 or something, which points to 1968 heads? Did Ford use the same heads for different year vehicles? We are not the original owners of the truck.
What started all this is that the front main seal in the transmission blew out so we pulled the tranny to take a look and replace the seal, but we are not sure if we should take it to AAMCO or something.
Old 07-22-2013, 12:51 AM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
What you have is a garden variety 360 used from 68-76. The blocks were all marked 352 between the 352, 360, and 390. The C8 heads were used until 76 for both 360-390.
Old 07-22-2013, 01:32 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
ALL FE engines look identical, there is no way to tell one from another by looking at them.
1968/76 F100/350 360/390 share the same block, the bore is the same (4.05"), the stroke is different.
Stroke: 360 = 3.50" / 390 = 3.78."
1958 thru circa 1971/72: 352 foundry mark cast into block. Reverse cast 105 appears on later blocks.
The 352 cast onto the block (on my '65 F100, it was on the left side towards the front) does not mean the engine is a 352, quite the contrary.
ALL FE blocks were cast as 352's, but when finished could any FE.
1968/71 360/390 head casting ID number prefix: C8AE / 1972/74 (possibly 1975/76) casting number: D2TE-AA (hardened valve seats).
Old 07-22-2013, 08:08 PM
Thanks for replying.
So I am to understand that the C8 heads do not have hardened valve seats?
Old 07-22-2013, 08:36 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
No they do not. Have your machine shop add them in. Then ask your machine shop if the valves are at standard height or are you going to need longer/shorter pushrods. New valve guides. Also a 3 angle valve job if you can afford. This is not necessary but nice.
240 And 300 Cylinder Head Differentiation trozei Ford Inline Six, 200, 250, 4.9L / 300 36 12-04-2016 03:03 PM
HUGE GAP BETWEEN INTAKE MANIFOLD AND HEADS naystcb FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 16 08-06-2010 07:48 AM
FE Block giving me a headache! MagickNinja 1967 - 1972 F-100 & Larger F-Series Trucks 10 02-24-2010 12:30 AM
427 Service Block? actioncam1 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 12-08-2005 05:53 PM
390 Rebuild rusty79 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 16 04-28-2001 09:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
