TTB Front Axle Type? - Ford Truck Enthusiasts Forums
Old 07-21-2013, 08:40 PM
hedgeapple hedgeapple is offline
hedgeapple is starting off with a positive reputation.
My truck is an '81 F250 4WD. It has the twin traction beam front axle(s), a Dana unit. I need to know how to identify which axle it is, Dana 35 or Dana 40. The carrier casting has some letters (A and a B, I think) and numbers (023) cast in.
The truck was built by a cousin from a number of different vehicles, and there's no way of knowing what vehicle the TTB came from, so I'm stuck with looking at the unit itself.
Old 07-21-2013, 08:47 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
There are only 3 ttbs. The dana 44, the dana 44HD, and the dana 50. Since you have a f250 with front leaf springs, you will have a dana 44hd or a dana 50. If you know someone with a f150, look at their hubs. If your 4x4 hubs are the same size as the f150, then you have the dana 44HD. If you have larger diameter 4x4 hubs, then you have the dana 50. Your truck would have come from the factory with the dana 44HD.
Old 07-21-2013, 08:57 PM
Well, that's simple enough. No f150 handy, but a friend has an 84 f250 with a 6.9 and I know it's a HD. I'll compare it.
btw, If you know a Dean Caldwell there in Staunton, tell him Deke sez hi. Statlers forever.
Old 07-21-2013, 09:11 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
Typically, if it's a regular cab it's the D44HD. Extended cabs got the D50. The 6.9 in a regular cab would get the D44HD.
Here's a visual ID.
Old 07-22-2013, 10:48 PM
My hub measures 3 inches. I suspect it's the 44HD.
Old 07-23-2013, 12:46 PM
garthneddy's Avatar
garthneddy garthneddy is online now
garthneddy is gaining momentum as a positive member of FTE.
I believe the D50 third members have the number 50 cast into the bottom as well.
Old 07-29-2013, 11:00 PM
2500ak's Avatar
2500ak 2500ak is offline
2500ak is starting off with a positive reputation.
look at the sticker in your drivers side door jamb, I think the D44 is a 3800 GVRW rating, the 50 is 5000 something I think..
Old 07-29-2013, 11:04 PM
bruno2's Avatar
bruno2 bruno2 is offline
bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.
Quote:
Mine does.
Old 07-29-2013, 11:07 PM
bruno2's Avatar
Quote:
Is it an 8 lug hub? If not surely somebody didn't swap in a D44. The rear is either the D60 or the Sterling 10.25 and both of those are 8 lug units. So surely you have the same lug nut count on the front as the rear?
Old 07-30-2013, 12:20 AM
2500ak's Avatar
Quote:
The D44HD has 8-lug wheelhubs, with 9/16 studs. It uses the same 19-spline lockouts as any other D44. I think most of the parts are D44 parts, but the hubs are definitely 8-lug.
Old 07-30-2013, 07:31 AM
Franklin2's Avatar
Quote:
You are correct, I believe Autozone says the 44hd is 3850 and the 50 is 4600lbs.
Old 07-30-2013, 11:13 PM
My 86 F250 Supercab with a D50 has a front axle weight of 3,920lb. I'll have to look at what my 87 F250 RC with the D44 is rated at.
Old 07-31-2013, 06:18 PM
Franklin2's Avatar
Quote:
I am not sure exactly how that works, but it may be the rated load in that truck. In other words, possibly a regular cab truck would have higher number since it's lighter. They may have subtracted the heavier weight of a extended cab truck, so that lowers the axle's capacity.
Old 08-01-2013, 06:11 PM
bruno2's Avatar
I wonder if it has anything to do with the spring package on the front?
Old 08-01-2013, 06:19 PM
Franklin2's Avatar
Springs should not change the axle weight rating. They would change how much it sagged under load, but stronger springs does not raise the axle's ability to carry a load.
1994 F250 axle question oldbutgood Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 12-14-2016 03:56 PM
82 F350 Axle Gearing Musicims 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 03-21-2016 08:27 PM
DANA 50 TTB Experts, help needed. badasssapper67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-17-2016 12:50 PM
D50 ttb axle casting numbers bullnose1985 Clutch, Transmission, Differential, Axle & Transfer Case 2 02-01-2015 10:31 PM
solid axle dana 50 in obs f250 HighboyHugger 1987 - 1996 F150 & Larger F-Series Trucks 6 10-11-2013 03:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
