Brewing temp got away from me - Ford Truck Enthusiasts Forums
Old 07-21-2013, 03:31 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Smile Brewing temp got away from me
I had preheated the WVO to 145 deg and transferred it to my mix tank. I usually lose a few degrees in the transfer. It was about 137 deg prior to adding KOH/meth so I turned on external heater and added chemicals. I shut off external heat at 140 deg. The temp continued to climb to 149.7 deg at which time it finally peaked only after forcing the temp to stop by placing heavy metal heat sinks in the mix. I was getting nervous. I vaguely remember the flash temp for the methanol to be 148 deg (I may be wrong). This is the first time I could not control the temp. Do you think it was a chemical reaction that caused this? I did add the chemicals faster than usual. The batch came out fine although I probably flashed off quite a bit of methanol. It was over temp for approx 45 min.
Wishing all my "brewing brothers" the best and thank you for your continued support of our forum
Tom D
Old 07-22-2013, 08:31 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Howdy Tom! I had it happen once and a small "cloud" of vaporized Methanol "floated" above the mix. Scared the crap out of me, but turned out OK........
Old 07-22-2013, 04:31 PM
Quote:
Hey Don
Great to see you are still keeping an eye on me and keeping me out of trouble
I certainly didn't want any kind of fire. That's my worst "F" word nightmare
Thanks as usual for the help all these times
Tom
Old 07-24-2013, 10:29 AM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
Quote:
Mixing KOH and methanol causes a remarkably exothermic reaction. I found that mixing them in a 5-lb cubie was dangerous, especially when I was in a hurry to get them mixed and added to a batch of hot WVO. I never popped the safety valve on my appleseed reactor, but I did have a fountain of methoxide one time because I added too much KOH too quickly to several gallons of methanol. Scared the hell out of me.
I'm betting that's what happened here ... gotta let the methoxide cool off before adding it to your WVO, or you'll see your temperatures climb. As long as you've got a pressure relief valve on your reactor, though, you should be all right.
Old 07-25-2013, 07:37 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
I've almost had the same thing happen, learned to shut off the heat around 120 - 125. Temp usually continues to climb as reaction takes place.
Good to see everyone's still active, thought this site would get busier as Diesel prices went back up. Running $3.85 here. Stay safe!
How hot is too hot for coolant? joegeds 1987 - 1996 F150 & Larger F-Series Trucks 1 08-11-2016 09:44 AM
2002 Explorer shuts off on it's ownThrott Eric3501 Explorer, Sport Trac, Mountaineer & Aviator 16 06-06-2016 12:15 PM
"Engine Oil Cooler" for a 2006 5.4 FX4 F150 PSWP 2004 - 2008 F150 8 10-21-2015 08:08 PM
Trans temps abnormally high for non-towing... intermittent GoCamping 1999 - 2003 7.3L Power Stroke Diesel 9 08-07-2014 12:02 PM
BSFC and Exhaust Gas Temps (EGT) Info MaxRaceSoftware Performance & General Engine Building 1 06-28-2002 01:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
