1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
16x10 best fitting tire????
Old 09-21-2013, 01:11 PM
2zwudz's Avatar
2zwudz
2zwudz is offline
What is the best fitting BF. Goodrich All Terrain tire for a 16x10 rim?
Thanks
Mark
Old 09-21-2013, 11:47 PM
Hotpocket's Avatar
Hotpocket
Hotpocket is offline
bump
Old 09-23-2013, 05:56 AM
2zwudz's Avatar
2zwudz
2zwudz is offline
Really!!!! No one has any experience with 16x10 tire fitment?????
Old 09-23-2013, 07:21 AM
caprisecca's Avatar
caprisecca
caprisecca is offline
thats a wide rim i wouldnt put nothing less a 12.5 inch wide tire on it
Old 09-24-2013, 07:53 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Welcome to FTE Mark!
From reading your posts, I appears that you have a 2004 Super Duty with the 6.8L V10 engine. I assume that it is 4X4, so please confirm.
Most people select a tire size to meet their expectations (height and width), then they select the wheel size. In short, the wheels support the tires. For example, my plans were to run 40X13.5R18 tires on 18"X10" wheels. Most tire manufacturers have recommended wheel widths as part of the tire specifications.
Toyo Tires only makes two tires (Open Country M/T) that are approved for the 16"X10" wheel. The 16"X10" wheels are TOO WIDE for the other 16" tires. They are:
LT315/75R16 (35X12.50R16) Approved Rim Width Range: 8.0-8.5-10.0
LT385/70R16 (38X14.50R16) Approved Rim Width Range: 10.0-11.0-12.0
Open Country M/T | Toyo Tires
I don't know if you are just researching or have already purchased the 16"X10" wheels, but you need to consider the "overall plan" for your Super Duty to include any future lift kits, towing requirements, off-roading desires, etc.
ALSO, YOU NEED TO CONSIDER THE BACK SPACING OF THE WHEELS FOR YOUR APPLICATION... YOU NEED APPROXIMATELY 4.5" OF BACK SPACING.
speakerfritz
03-01-2014 08:26 AM
Mainesupercrew
03-13-2009 03:09 PM
Longneck
03-11-2004 08:18 AM
reveye
02-16-2003 02:07 PM
Quick Reply: 16x10 best fitting tire????
