Sensor issues; swapping a 95 for 99 engine: - Ford Truck Enthusiasts Forums
Old 07-21-2013, 08:35 AM
scottdeese scottdeese is offline
scottdeese is starting off with a positive reputation.
Unhappy Sensor issues; swapping a 95 for 99 engine:
I am helping my mechanic (shade tree) put a 99 vulcan engine into my 95 ranger. there seems to be alot of uncertainty concerning the sensors. one on the front has different connector then the wire for it has; And he said he can't find the wire that goes to the camshaft sensor. Are there alot of differences in in 1999- 3.0 and the 1995- 3.0 engines?
I am not sure if the guy seen a place to put the new cps on the 1999 engine. Will the computer work with this other engine? What have I got myself into? Also, with the wire connections not matching the sensor connections, what would be the wisest; change the wire connections or change the sensor. I think my mechanic will choose the easiest solution regardless of whether it is right, and not care about experimenting while I am paying the bill. I already have more money in this truck then I will ever get out of it. My only hope is that it works well and for along time. Any advice is appreciated.
water coolant temperature sensor grang46 Aerostar 6 07-12-2013 08:17 AM
2003 6.0 ICP Where do I unplug it?? TOSHA20 1999 to 2016 Super Duty 1 12-19-2012 03:55 PM
2003 6.0 ICP Where do I unplug it? TOSHA20 6.0L Power Stroke Diesel 7 12-19-2012 03:27 PM
'98 4.0 engine swap 427supersnake Explorer, Sport Trac, Mountaineer & Aviator 1 12-01-2011 07:38 PM
99 f250 4x4 - changed tranny seal, now backfiring/stalling issue?? futureislime 1999 to 2016 Super Duty 2 08-09-2009 08:11 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
