Help oil pressure gauge not working, new to me truck, 1993 F250 4x4 extended cab automatic
I have read through countless posts on here about the oil pressure gauge.
I understand that it is basically a glorified idiot light, and will work if there is atleast 7 lbs of pressure.
I also read you can convert it to a regular gauge, which I will do at some point: Ford Oil Pressure Gauge Fix
I just bought this truck, and it has not showed oil pressure since I bought it (few days ago), I towed it home and have not started it since previewing it and seen that it has no oil pressure on the gauge.
They claim that the gauge quit working 4 months ago and they have been driving it since... but I'de rather be safe than sorry, truck does sound pretty good, and starts right up easily.
Most people say to install an aftermarket gauge, since these trucks idle around 8-10 PSI pressure I want to get a gauge that has the numbers spaced out so that its easier to tell what its reading... if that makes since. EDIT: (just found out its called a wide or full sweep gauge, not a short sweep)
I dont really see any recommended kits... I know that I want to use a sender... dont want to run the risk of an oil leak at an extra spot and dont want an oil line running into the cab.
If anyone has any recommendations for a good gauge kit let me know.
I am wondering... if I hookup the gauge and still have no pressure.... what all could it be?
so far I can only think of two things... oil pump or clogged pickup screen.
After a bit of searching this is the gauge I am thinking of getting: Digital Oil Pressure Gauge ProSport EVO Series Blue Red | eBay
anyone tried one of these? are they ok? the brand at the bottom says prosport, never heard of them...
hmmm looking at it again... it would be better if the range was 0 to 100 instead of 0 to 150....
EDIT: found one that goes to 100 max... would give a more clear reading I think: http://www.ebay.com/itm/370646362050
I've got one of these: http://www.ebay.com/itm/2-52mm-White-Oil-Pressure-Press-Gauge-0-120-PSI-Digital-Blue-LED-For-Car-Truck-/160816957511?pt=Motors_Car_Truck_Parts_Accessories&hash=item2571700847&vxp=mtrSeems to work decently, though it's "danger light" comes on at 18PSI, and my truck runs 12 PSI at warm idle.
Probably not accurate to the PSI(especially not if you've got grounding issues, as these are one-wire senders), but definitely responsive enough and a good relative measure anyway.
I seen those on there too and was wondering when that danger light would come on, thank you.
Interesting, I wonder how that danger light works... if its just a resistor or something you might be able to solder in a different size one and make the danger light come on at like 8psi instead.
EDIT: I am just very eager to find out if there is an oil pressure issue on this truck or not. Cannot wait to start driving it.
I went to pick a part today and replaced the broken out wing window, and then I bought a new power window motor for the drivers side and got all of that done.
I should have mentioned! This truck has a bad oil leak, I am going to start with the valve cover gaskets and then clean the motor up and go from there...
The craigslist ad said that it goes through about 1 gallon of oil per month, they would just check it and add to it daily... The other issues is that it will drain both batteries dead within 2 days if you dont unhook them, and the wing and window were screwed up on drivers side which I fixed today.
So really once I figure out if my oil pressure is ok and take care of the drain on the batteries, I will be good to go!
I had same oil pressure problem. I replaced the sending unit 3 times in 5 years. (always the same thing) I also converted the factory gauge to direct reading (as you mentioned doing) I got tired of glancing at my dash and seeing 0 PSI while I am ripping down the highway at 70 MPH (tough on the heart) so I added a direct reading gauge (oil to the gauge). It gives me great peace of mind to see 40 PSI when the crappy factory one is reading low.
Tom D
Tom D
Received 3,090 Likes
on
the second gauge you listed looks like a decent unit. i have no experience with it, but i would buy one if i needed an oil pressure gauge.
as for the dead batteries in 2 days if not unhooked, hook up the batteries and feel the alternator after 2or 3 hours. if it is hot, it has a bad diode in it and is what is killing the batteries.
there are other tests, but that is a good first test.
I feel good with my aftermarket gauge... Want an electric though!... Fear of oil spray is pretty bad!... As for your battery drain it could be the alternator(I think diodes) can't remember the exact part in the alternator but been told that can drain your battery when it goes bad... Easy way to test it is a multimeter, disconnect the wire from the terminal on the alternator and see if its drawing power or not, other than that only thing I can say is hook up a test light to the pos. terminal of the battery with the cable disconnected and hook it to the cable that you disconnected and start pulling fuses till the light goes out
Tom
