1990 F-250 trans swap flexplate issues
I have a 1990 Ford F-250 with a 7.3D and C6 automatic transmission.
I'm currently doing a transmission swap to a 4R100, with a 6-bolt pattern torque converter.
The existing flexplate has a 4-bolt pattern and is externally balanced.
Which flexplate can I use, and where can I get it?
Thanks for any help!
Received 3,102 Likes
on
Hi and thanks. I'm aware of that. I have a Compu Shift II TCU so that is not an issue, the issue is the flexplate...
If you want to use a six stud converter, you might get away with drilling the late stamped style flexplate.
RJ285
01-18-2015 12:23 PM
