looking for a good 6.0L fird diesel mechanic, bessemer - Ford Truck Enthusiasts Forums
Alabama Chapter Join Chapter , Leader:
Old 07-20-2013, 11:05 PM
BryanStein BryanStein is offline
BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.
New to diesels and new to the ford 6.9.
Looking for a good 6.0 mechanic in the McCalla, Woodstock, Bessemer, Bham, Vance, Cottomdale area.
Anybody know one?
2004, F250 215k miles. Need oil cooler. Delta T is 30 degrees.
EGR deleted I've been told, but I can't prove it by looking. EGR chamber is still there and must have coolant flowing through it. EGR valve still in place. I can't tell if a plate has been installed over the exhaust up pipe connect to the EGR, but this is the only way I know to delete the EGR cooler with the chamber in place.
Present oil cooler only has 50k miles on it.
Thanks for the recommendation.
EGR delete and what else? D2Gags6.0 6.0L Power Stroke Diesel 0 01-14-2014 09:30 AM
Just completed oil cooler install. EOT-ECT was 40 degrees. BryanStein 6.0L Power Stroke Diesel 10 07-27-2013 02:52 PM
Replacing oil cooler. What else should i do while there BryanStein 6.0L Power Stroke Diesel 9 07-21-2013 12:32 PM
Oil temp 210, ECT 190, egr delete at idle BryanStein 6.0L Power Stroke Diesel 18 07-21-2013 06:51 AM
EGR system...Check this out. 2006powerstroke90 6.0L Power Stroke Diesel 22 09-27-2011 07:52 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
