1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
08 6.4l engine/transmission problem
Old 07-20-2013, 09:58 PM
blacksmoke2008's Avatar
blacksmoke2008
blacksmoke2008 is offline
my 2008 f250 6.4l just got out of the shop a week a go new small block and new pistons, throwing #1 constrabution code,map sensor and #1 cil missfire you can hear air come out of the intake, im guessing valve train or lifter..... other problem two days after the truck throwing the codes i went to take it to the shop and would barely drive floored stuggle to go 10mph put it in park rev up normal will go in reverse normal just no power in drive, no transmission codes, had it towed to the diesel shop, mech said might be a fail safe on transmission from the engine codes?? any help here? it has egr/dfp h&s mini maxx tuner, the truck has 170k on body 11k on new engine before the new block that was put in last week.
Old 07-20-2013, 09:59 PM
blacksmoke2008
oh and all fuilds are good....
Old 07-20-2013, 10:03 PM
Hotpocket's Avatar
Hotpocket
Hotpocket is offline
i'm no expert but it sounds like it may have a torque converter problem
Old 07-20-2013, 10:14 PM
blacksmoke2008
good point....thanks ill look into it
Old 07-20-2013, 10:23 PM
Hotpocket's Avatar
Hotpocket
wait till Mark K chimes in...he is the best tranny expert on this forum
Old 07-21-2013, 05:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Why does everyone immediately go to the torque converter? Is it the only part of the transmission you can identify? How in the world could it be the torque converter if it works in reverse but not drive? How would the torque converter do that? How would the torque converter know that the trans is in reverse and not drive?
I think it is in a fail safe mode. Get the engine fixed and the trans will probably be fine.
Old 07-21-2013, 07:17 AM
blacksmoke2008
thanks mark. Good point.
Sheriffdude
08-11-2018 11:34 PM
slhawkins
1997 - 2003 F150
11-01-2012 07:23 PM
Gkerwoo
10-22-2011 10:16 PM
justin_tractors
05-16-2003 12:25 PM
Quick Reply: 08 6.4l engine/transmission problem
