94 Fuel economy, gear ratios, tank size - Ford Truck Enthusiasts Forums
Old 07-20-2013, 05:30 PM
64F260 64F260 is offline
64F260 is starting off with a positive reputation.
I am in the process of buying a 94 F250 4x4, and have a lot of newbie questions. I haven't checked the rear end for a plate or numbers, but the seller says it has 4.10's. The rpms seemed low for that, at 60mph the rpms were just under 2000. (tires are 235 85r 16) It has the automatic trans with overdrive. Does this sound correct for 4.10 gears?
It has the factory dual tanks, what is the capacity? (It is the supercab, does this make a difference on tank capacity?
What is realistic mpg for these trucks?
The truck was built in May of 94, and has the turbo IDI engine (pre-powerstroke).
It does have some brake fluid seeping on the master cylinder, behind the reservoir, so I figure that will be my first project. Pedal feels good, but don't want it to get worse.
Old 07-20-2013, 07:00 PM
Orpackrat Orpackrat is offline
Orpackrat is starting off with a positive reputation.
I had an '88 7.3 IDI with 5-speed I could push to 20MPG hwy but typically got 18MPG.
Old 07-20-2013, 08:21 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I think the tanks are 19 gallons each
Old 07-20-2013, 08:36 PM
Thanks for the info. Ought to be able to go some distance on those tanks!
Old 07-21-2013, 04:02 AM
genscripter's Avatar
genscripter genscripter is online now
genscripter is starting off with a positive reputation.
I have 4.10 and 235 85 16 tires with the C6 tranny but an aftermarket OD. You have the E4OD. So for all intensive purposes, we have the same setup. When I'm driving 60mph, I might be just around 2000 rpms (I don't have a tach), so maybe your rig is a 4.10.
Old 07-21-2013, 04:46 AM
Golden Helmet's Avatar
Golden Helmet Golden Helmet is offline
Golden Helmet is starting off with a positive reputation.
My truck has the 4.10's, no turbo, and it's at just about 2k rpms at 60-65mph give or take a bit. I filled it today and got about 11.5 MPG, but I haven't been very nice to it lately. Best I've managed is about 14.2. That's with an E4OD, 4x4, extended cab, toolbox with junk, and other bits and bobs weighing it down, plus I have no clue if the timing has been done or the IP replaced. If it ain't broke...
I'm not sure about the fuel tank sizes, I think it was 18 and 16? The previous owner of my truck replaced the rear tank with a 45 (!!!!) gallon tank, and I don't use the front tank often since the gauge doesn't work on it.
Old 07-21-2013, 09:57 AM
snowdog79's Avatar
snowdog79 snowdog79 is offline
snowdog79 is gaining momentum as a positive member of FTE.
19 gallons front, 18 rear. I've been between 14.4 and 18.5 mpg, seems to depend mostly on speed, with 4.10s anything above 65mph and the mileage seems to drop quickly.
Old 07-21-2013, 12:53 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
I like to run on the interstate and I got consistant 11, the po said 15 was possiable with it.
Old 07-21-2013, 03:30 PM
Wood.'s Avatar
Wood. Wood. is offline
Wood. is starting off with a positive reputation.
5spd 4x 7.3 banks. 235/85 4.10
i get 16 with a heavy foot. and i think my front tank is bigger than my rear.
Old 07-24-2013, 06:38 PM
KrautBurner's Avatar
KrautBurner KrautBurner is offline
KrautBurner is starting off with a positive reputation.
I've got the 5 speed with the IDITurbo (got her last night)
I plan on filling my tanks today, and seeing how she does
Old 07-24-2013, 09:40 PM
Macrobb's Avatar
Macrobb Macrobb is online now
Macrobb is gaining momentum as a positive member of FTE.
I've got an 88 F250, extended cab, non-turbo(so with a turbo you should get better) 5-speed, GV and 4.11s... I've been getting 16.8 fairly consistently recently with mostly highway(62mph+-1mph) driving. I think I could/can get better... I've hit 19 occasionally, but it's also a well-worn engine.
Old 07-30-2013, 10:13 PM
I think I run about 2,200 rpm in 5th at 60mph
Old 07-31-2013, 12:33 AM
kc0stp kc0stp is offline
kc0stp is starting off with a positive reputation.
Ya I see around 7-13mpg pending wind normally but normally mines married to a 24' enclosed trailer
Old 07-31-2013, 11:04 AM
geniusloerts's Avatar
geniusloerts geniusloerts is offline
geniusloerts is starting off with a positive reputation.
I've got a 93 N/A at the moment with 3.55 and e4od. I am cruising at 65mph @1700ish and 70mph @2000 I have 255/70/17 on it at the moment. getting around 17mpg
Old 11-08-2013, 07:20 PM
Thanks for the info. The truck I was going to buy a couple months back never happened, and today I was fortunate to buy a 1994 F250 with 5 speed and 4.10s It has very low miles on it! Already wondering if it would be worth it to swap to 3.55 gears or something for gas mileage.
92-96 f150 bumper towing max capacity NotSoSporty98 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 14 11-19-2015 03:35 PM
Gears. Rambo76 1987 - 1996 F150 & Larger F-Series Trucks 24 11-03-2014 01:21 PM
1994 F350 GCWR & Towing Capacity BlueOvalLover 1987 - 1996 F150 & Larger F-Series Trucks 10 06-30-2014 06:00 PM
4.10 vs 3.73 on MPG Joshey93 1987 - 1996 F150 & Larger F-Series Trucks 6 03-08-2014 12:22 AM
1992 f-350 Towing Capacity? daddylee100 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 06-17-2013 06:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
