Funny trailer tire wear
Hi everyone,
I've never dealt with abnormal wear on a trailer before so I figure I'll seek some opinions. My boat rides on a 2011 Shore Land'r trailer with a 3,500 lb axle. Trailer tire pressure has always been maintained to 50 PSI and the trailer probably has between 3-4,000 miles on it. This season we've noticed drastically increased tire noise coming from the trailer, so I checked it out today. This is what I found:
This was the left side tire. the right side was unevenly worn on both shoulders of the tread which led me to think it was underinflated. But the only way that could happen is if the boat is too heavy for the trailer, as the tires are rated for 50 PSI at maximum capacity.
What am I missing here? Why is my trailer eating tires?
It's on the inside. The other tire is worn badly on both sides of the tread; the middle looks just fine. But it was never underinflated. Thinking I may need to get this thing on a scale.
Looks like it may have a bent axle stub. Since most people run their trailer wheel bearings loose, the wheel will **** under a bit and wear like that. I run my bearings like the front wheel bearings on my truck since I do mostly highway towing, and when I have an axle problem it'll wear the tire like that but all the way across.
How does the trailer track?
Here is a link for trailer tire wear it will make it clear as mud https://www.google.com/search?q=trai...%3B1275%3B1650
I'm guessing it may be towed out causing the feathering, the tire has a aggressive tread on the last rib so it would make the feathering more pronounced, but the wear on the other tire sounds like overload or under inflation so it may be more than one problem. After you weight it you will know more.
Denny
Denny
Look closely, do you see any seperation in the tread, look close now. I have had this on my 5er, took off the tire, took it to Discount Tire. They aired it up 5 psi over rated and showed me seperation in the tread. The first indicaiton is the more oval shape of the tread and not flat, as if a belt had broken but yet not. Just thinking out loud here.
Wow Denny, what kind of rig does that go on? LR H is what class 8 trucks use.
Denny
