Lost oil pressure in my 460 - Ford Truck Enthusiasts Forums
Old 07-20-2013, 02:06 PM
Jxltrucking Jxltrucking is offline
Jxltrucking is starting off with a positive reputation.
I have a boat with a 460 and I lost oil pressure was having problems with water in the oil and replaced all the gaskets from the heads up and on start up I'm not getting oil pressure, I'm spinning the oil pump with the distributor out manually and I pulled the line off of the remote filter housing and it's moving air in pressure and vacuum but their is no oil making it to the filter
Old 07-28-2013, 09:47 AM
retro48/52's Avatar
retro48/52 retro48/52 is offline
retro48/52 is starting off with a positive reputation.
Had a 302 in a boat. Oil pickup tube came loose and no pressure but pump turned.
Had to take engine out to find that problem. Maybe yours also? JAT
Old 07-28-2013, 10:22 AM
Just pulled the motor yesterday snapped rod and it hit the oil pick up tube problem found thanks for your help
Oil Sender question _Trekker 1987 - 1996 F150 & Larger F-Series Trucks 1 02-18-2017 11:22 PM
LP Oil Draining down Overnight FiveOJester 6.0L Power Stroke Diesel 4 09-06-2016 06:30 PM
oil pressure and coolant temp sensor mounting 86scotty Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 05-19-2014 09:51 AM
oil pressure too high!!!??? dagomachining 1967 - 1972 F-100 & Larger F-Series Trucks 21 11-10-2013 12:12 AM
V10 Seized After Oil Pressure Loss shortyf-250 1999 to 2016 Super Duty 21 09-15-2009 07:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
