Propane Injection: What Do I Need To Know? - Ford Truck Enthusiasts Forums
Old 07-20-2013, 01:38 PM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Hey guys. Im looking to upgrade the ol Stroker and squeeze some more power out of it. The engines coming out to fix some problems and going back in in hopefully not stock form (depending on budget).
I think I can plumb the propane myself without a problem. Will I need a custom tune to make it work or is it plug and play? And can it be installed to come on at the flip of a switch or will it need to run the entire time the engines running? I have zero experience with propane. Thanks guys!
Old 07-20-2013, 06:04 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
There are several ways to make good power out of a 7.3 A set of stage 1 injectors, t500 hpop and a good fuel system will make you good reliable power. Propane is called "Propain" for a reason... I highly suggest that you don't mess with it.
Old 07-20-2013, 06:39 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
I wouldn't bother with it.
If you want a little more power on a budget look in to water/meth kit
Old 07-21-2013, 01:20 PM
Those two posts are enough to make me shy away lol. Thanks guys!
Old 07-21-2013, 03:41 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
Seriously, me too. Penny Saved for injectors!
Old 07-21-2013, 05:49 PM
If you give Jim Rose over at Rosewood Diesel a call he can get you setup with injectors and you will find you don't need as many pennies as you think lol.
Old 07-21-2013, 07:57 PM
130,000 pennies is a lot in my opinion lol. But money well spent!
Old 07-22-2013, 12:47 AM
Hahah around 50,000 pennies from Jim. If everything checks out.
Old 07-22-2013, 09:58 AM
"If" lol. On Rosewoods site they say injectors hardly ever pass inspection lol
Old 07-22-2013, 10:29 AM
Quote:
after 200,000+ miles of truly unknown diesel you have to assume the injectors will be a little beat up. then my fear is waking up the engine and surprising the transmission! they are very used to each other. i assume op is handling that separately.
Old 07-22-2013, 12:24 PM
Its still under deliberation lol. Im stuck between keeping the auto and upgrading it or sinking several grand into a parts truck with a ZF5. I think in the end keeping the auto would be cheaper and less work but its sure fun driving a stick!
Old 07-22-2013, 02:25 PM
either way will be good, it's just that i'm a fan of preparing for the power rather than repairing the damage.
Old 07-22-2013, 05:51 PM
^^^ You got that right. I HATE transmissions in every way, shape, and form. Theyre a HUGE PITA to take out, fix, and reinstall. Especially the reinstall... Id rather spend some cash and make sure the tranny up to par than have to take it back out in a couple weeks lol
Old 07-22-2013, 08:32 PM
fordpride's Avatar
A built E40D will cost you 3-5k
Old 07-23-2013, 10:30 AM
To have someone build it, yes. I plan on having my father-in-law do it so it "should" be a lot cheaper lol. I haven't priced parts yet
Propane Conversion on my Edge - 6 month report PaulsEdge Alternative Fuels, Hybrids & Mileage 7 01-09-2017 08:09 AM
New take on propane? Dobies4life Alternative Fuels, Hybrids & Mileage 15 06-01-2014 01:27 AM
timing on propane engine joey2fords Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 04-14-2014 01:06 AM
Bullydog Propane Tank jonnybronco Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 03-07-2014 12:27 AM
Propane/Gas Engines the law Performance & General Engine Building 7 11-07-2002 06:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
