JB WELD ON RADITATOR AND HOW TO FIX LOW OIL PRESSURE
Old 11-03-2012, 07:02 PM
waystro's Avatar
waystro
waystro is offline
will jb weld fix a hairline crack in a raditator or what other simple repair will work. allso i have low oil pressure what would cause that thanks
Old 11-03-2012, 07:22 PM
mudguts's Avatar
mudguts
mudguts is offline
On the radiator you could try JB weld or some thing else personal I would just replace it. The oil presure on these engines at an idel is around 7-10 psi how many miles are on it ?
Old 11-03-2012, 08:45 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Oil pressure, you might try replacing the sending unit, they read low on their way out. For the crack, get some 80 grit and rough it up good and ya you can JB weld. If its brass i would have it soldered
Old 11-05-2012, 04:53 AM
hookedondiesel's Avatar
hookedondiesel
hookedondiesel is offline
Clean the "hairline" crack with muratic acid,
apply some solder paste and solder it yourself.
Old 11-05-2012, 05:22 PM
kobaltblue's Avatar
kobaltblue
kobaltblue is offline
If its a small hole on the tubes JB will work if you get it really clean, If you dont and it still leaks there is no way to fix it unless you cut and solder the tube ends (Not too hard to do)
If its on the tank you need to clean it good if its a small crack you could try to solder it but if it doesnt work go to the hardware store and get a small copper fitting cut it open then flatten it out and shape it and make it into a patch clean really good then solder.
Old 11-05-2012, 05:28 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
ive got a jb welded radiator from previos owner and it works.. 'its better then bailing wire' says so right on the package!!
Old 07-21-2013, 01:04 PM
nw_ia_guy's Avatar
nw_ia_guy
nw_ia_guy is offline
I hit a washout with my 6.2 diesel suburban & the driver's side battery mount broke & the battery tipped into my radiator The neutral post punched a hole in my radiator. I was on a logging road 60 miles from any hard surface. I cleaned it up, and took a heap of JB Weld, gooped it on, put some duct tape on it to hold the glob in place and left the truck for a week while I portaged in to fish. A week later it was just fine and still is 6 years later! It works!!! I also punched a hole in my lower unit on my 40 horse big enough to put my little finger in, globbed JB on it and stuck an American quarter over it & it lasted 10 years.
Old 07-21-2013, 01:37 PM
Wood.'s Avatar
Wood.
Wood. is offline
buy a new radiator and rebuild the motor. problem solved.
jb weld on a radiator? come on guys...
Old 07-21-2013, 01:50 PM
bashby's Avatar
bashby
bashby is offline
I JB welded a crack in the upper tank of my 88 toyota about 15 years ago. Still holding.
As advised, clean the area and scuff with 80-100 grit sandpaper real good.
Old 07-21-2013, 06:38 PM
kobaltblue's Avatar
kobaltblue
I had a John Deere 300 skip loader I bought it cheap from the PO who didnt put antifreeze in it cracked the engine block along a water passage, Cleaned up lobed on a good bit of JB filled it with anti freeze and used it for 10 years that way,And sold it for a nice profit....That stuff works
Old 07-22-2013, 12:31 PM
flainn's Avatar
flainn
flainn is offline
Must be good to have money coming out your ears.
Old 07-22-2013, 12:52 PM
madpogue's Avatar
madpogue
madpogue is offline
Originally Posted by nw_ia_guy
....globbed JB on it and stuck an American quarter over it & it lasted 10 years.
About the only way money holds its value anymore.....
Old 07-22-2013, 02:07 PM
fuzzy1626's Avatar
fuzzy1626
fuzzy1626 is offline
Not to highjack this thread but I've never used JB so I looked at their site. They've got a JB for everything... I need to get some to keep in my truck.
Old 07-22-2013, 04:52 PM
bashby's Avatar
bashby
bashby is offline
The stuffs even gas proof. I patched a hole in the fuel tank on my zero turn with it.
Old 07-22-2013, 07:34 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
JB Weld is a great product. The problem with Radiators is the constant expansion & contraction of it. Take it to a radiator shop & have them rot it out & brass it if metal.
If plastic buy a new one. Cheaper than fixing.
Craig
BossBulldog
09-10-2011 11:49 PM
79f-250custom
13
10-28-2007 09:05 AM
84f250460
06-23-2007 07:55 PM
Rexman
02-23-2005 01:06 PM
scalezy3b811
Oil & Lubrication
11-17-2004 06:00 PM
Quick Reply: JB WELD ON RADITATOR AND HOW TO FIX LOW OIL PRESSURE
