Need a Starter Push Button - 49 Ford
on
I recently bought a "reproduction" starter button on Ebay but it would not fit into the hole in my dash. Ordinarily, I would enlarge the hole and make it fit but my dash is already painted.
Anybody know where I can get an original button or a repro that will fit?
Dennis Carpenter part #6a-11500 all chrome $7.00 Sacramento part #6037 $7.95 chrome ring, black button. DC, dennis-carpenter.com 704-786-81369. SVF 1-888-ford-100. www.vintageford.com.
Keep in mind that 48-51 starter buttons are grounded to the dash and only have one wire. '52-on have two wires and send battery voltage to the starter. If you are using a 12v solenoid you likely want the newer one. They are physically identical AFAIK. Even if you are using the original 6v solenoid that gets grounded, you may want to use the late-model and run one side of the switch to a good ground, rather than sanding the edges of the hole to get a good ground.
Napa carries it, they may not have it in the store but they can usually get it in 1-2 days. Part #ECH STB1 Or you can buy it online from them.
They didn't have that one in stock when I needed mine, so I got #ECH STB6301 instead, which is the two wire. I connected a ground wire to one side and the other to the solenoid.
6A-11500 .. Starter Button / Obsolete
1948/51 all trucks / 1949/50 Ford/Merc Passenger Cars / 1951 Ford/Merc Station Wagons.
2C-11500-A .. Starter Button (Motorcraft SW-287) / Available from Ford
MSRP: $11.02 / FTE sponsor tousleyfordparts.com price: $6.06.
1952 all trucks / 1965/66 F100/250 & 1966 Econoline Windshield Washer Button.
Moe Craig
17
06-06-2011 02:48 PM
48fordjeffie
06-20-2010 11:37 AM
RedStroker6
05-17-2005 04:15 PM
51dueller
07-31-2004 01:36 PM
