Water Temperature - Ford Truck Enthusiasts Forums
Water Temperature
Old 07-20-2013, 03:32 AM
jjurva! jjurva! is offline
jjurva! is starting off with a positive reputation.
Water Temperature
I have a 292 y block in my 60 f100. The temp gauge sits just past half way. Is this normal? I will touch the intake manifold and heads after driving for awhile and they are too hot too hold your hand on. Is this normal?
Old 07-20-2013, 07:52 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Quote:
The gauges were never meant to be calibrated. Has the point that the gauge reads changed? It may make you rest easier if you were to get a cheap infrared thermometer or other means of reading the actual temperature at the intake manifold by the thermostat housing. That is where engine coolant temperature is perhaps best read.
Also, I don't hold my hand on a hot dashboard that's been sun-baked. Yet it seldom exceeds ~150 F. Your engine is running at a coolant temperature that's approaching boiling. Not something that's comfortable by any means.
Old 07-21-2013, 03:17 AM
I just wasn't too sure. The truck has been sitting for 10 years + and I didn't want to old truck running to hot!
Old 07-21-2013, 07:42 AM
You'd do we'll to thoroughly rinse out the radiator and put new coolant in it.
Old 07-21-2013, 08:47 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
At a minimum, you want to drain out some of the coolant and install new stuff because the corrosion inhibitors get used up over time. Probably not so bad with brass radiators and steel blocks, still.
If anything what you really want to do is make sure the engine is getting hot enough, believe it or not, and soon enough, too.
Even if the temp Gage isn't perfect calibration it should be close enough?
Old 07-21-2013, 10:13 PM
This may be handy. I posted it on 48-56 forum:
BTW: I check it by deliberately filling it to the rim after flushing. I then look, with cap off, for the thermostat to cycle as it starts to warm up. You'll see the water suddenly flow, stop, flow again - if the radiator has cold water in it. Then I put the cap on and wait to see it overflow a bit as the water expands. Then it will find its happy balance. I do this every spring and whenever I buy a new used vehicle. It's cheaper than trouble on the road!
Old 07-22-2013, 12:11 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Good Point! I wish my engine would run at least 180 at cruise, rather than 160.
Please, no suggestions though! It has all been covered.
Old 07-24-2013, 01:02 AM
Thanks for the input. I wont worry about it unless I see it getting hotter yet. I will check to make sure everything is flowing ok and may even flush the radiator as suggested.
Old 08-02-2013, 01:34 AM
chetspencer's Avatar
chetspencer chetspencer is offline
chetspencer is gaining momentum as a positive member of FTE.
I just went from a 7 lb cap to a 16 lb cab and noticed a much cooler yet steady temp a hair past midway on the gauge of my 59 F100 292.
A major improvement yet I'm not sure why.
Running a Aluminum Crossflow radiator with Delo ELC CAT EC1 (Red color) antifreeze rated for 800,000 miles.
Water pump / fan wobble normal? airjeff 6.0L Power Stroke Diesel 18 10-13-2016 02:04 PM
EBC Green Stuff Brake Pads any good? LivingLarge Excursion - King of SUVs 19 12-07-2013 06:21 AM
too much black smoke? redsadam Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 07-28-2013 06:52 PM
Brake lights 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 4 07-08-2013 02:54 PM
Radiator hose hot and tight, normal? Dansco Ford Inline Six, 200, 250, 4.9L / 300 6 06-14-2002 07:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
