My new Ex and a question
Hey all. First time poster here from Southern California. Just recently purchased my first Ex and would liken to share as well as ask a question. I noticed when next to another excursion that in may be a little lifted. Such as a leveling kit or some sorts. I have a pic I'll like to post maybe someone can tell me... Here is the pic.
So was curious what size tire I can run on her without an issue. Next is a pic of current wheel setup and the ex herself.
In the front, how far off the bump stops are you? Post a pic, if you can, and that'll help us figure out of the front is stock height, too. The rear certainly is, as others have noted.
What size are your current tires? I run the same BFG's you have, as do lots of other folks, and 285/75 will fit if the front is stock, and fit better if you have V-code springs up front. We'll need the aforementioned photo to figure that out, though.
Mark
Mark
Hey all thanks for the welcome. The excursion is a 2000 limited edition with currently 87k on her V10 gas 6.8 engine.
Here is a pic of the front suspension (hope I got what you were asking for)
What is the typical lift you all go with? I read somewhere about 4" using F350 springs and 2 1/2 spacer up front with a 4" leaf in rear?
most of "us" use F-250 springs front/rear and that will give you about 2" over the stock height.
it's called the V/modded B swap. search the forum here. it's pretty much the most popular suspension mod for the Excursion besides a complete aftermarket lift.
I've got about $250 in my Excursion suspension doing a version of that swap and gained 2". very worthwhile mod IMO
It's all in the tech folder thread stickied at the top of the Ex forum.
It's usually a hair less than 2"
Here's mine after the swap, sitting next to a stock sprung 4x4 Ex.
Stewart
Stewart
Rockstar, welcome to the forum, we are all more than happy to help you spend your money!
I agree that your suspension looks to be stock, ya gotta love all that spring travel Ford gave us up front! NOT!
Do not ever use spacer blocks on the front! They can be dangerous and are actually illegal in many states including here in PA. Mini packs are a different story because they spread the load and roll resistance out over a longer section of the spring.
The guys above have given good advice and info on the common V/modded B swap, a good mod to cure the weak factory EX springs.
I was fortunate to have a coworker give me a low mile set of X code (snow plow prep) fronts and B code rears for my EX. Having been blessed with not only good looks and brains but also creativity (well maybe not so much on the first two.....) I took the mod a couple of steps farther. The B code rears sometimes come with an overload leaf that we can't use as the EX lacks the extra frame mounted blocks for this leaf to sit against, and this leaf if left on the spring pack can damage our rear AC lines so it has to come off. Being a waste-not-want-not kinda guy I took those overload leaves and added them to my front X codes, this increased the spring capacity and ride height as well as ride firmness. Out back to keep things moving in the same direction I did the typical B code mods that use the bottom two leaves from the stock EX pack and the thicker EX spacers. In addition to that I cut up my factory slapper bar from the EX pack and put two sections of it on each side and swapped out the stock EX blocks for the taller F-350 3.75" tapered blocks. These mods netted me 3 7/8" front and 4 1/2" rear, it looks good (to me) and the ride is a nice firm truck like experience, just like I wanted. This swap cost me about $75 in new U-bolts, a couple of afternoons and evenings and two six packs for my brother inlaw who gave me a hand handling the heavy springs.
With this much lift the EX is screaming for bigger tires, then if you tow at all the bigger tires call for a gear swap. I had all of this worked into my plans, the springs and gears are done, now I just have to wear out these tires some more and upgrade to the 35's I want.
The springs, B code on top, X code middle, modded X code bottom.
The Jolly Green Giant all stock.
After.
Good luck with your green beast!
After.
Welcome - let the fun begin!
I did the V/B mod to my 2000 7.3 (love it!) and just had to do something about the tires. I went 295 BFGs and they rubbed at full turn (as did 285s). Some will say that a little rubbing is not a problem - me, it make me crazy. To get rid of the rubbing I had to change wheels and go with something with less back spacing and neg offset.
This is what I ended up with.
hey WE3ZS I just did a V/modded B swap with winch bumpers on my X and the front has come down a bit from the weight of the winch and bumper. I have a 2" difference from front to back. Was thinking about doing something like you did and was wondering how the ride is. My truck has a 6L. Thanks
