4.9 300 1992 coil wires please help
Hello. I have a 1992 F250 4.9 300 manual transmission, fuel injected. After attempting to fix an issue with hesitation, stumble and bog when accelerating and very rough running when warmed up (which I still haven't fixed ahhhh!) but there are two wires that make up the harness that connects to the coil. Somehow they came out of the plastic harness. I want to know which wire connects to which terminal. Does anyone know exactly how these go? Which one goes toward the rear and which one goes toward the front? Please and thank you in advance. Sincerely.
Thank you for the answer
Awesome! Right on man. Thank you for the prompt and albeit correct answer. It worked. Now I'm narrowing down the original problem. I disconnected the green egr vacuum and she's running a lot better. Still has a bit of a stumble at the high end in 5th gear. But I'm getting closer. Thanks again!
I just unscrewed the tube and placed a 3/4" fender washer with a 1/8" hole between the EGR tube and the valve itself and the truck runs beautiful. No roughness, no CHECK ENGINE, and a little bit of EGR flow to keep things happy. Last winter I did as you did and just enjoyed the warm glow of the CHECK ENGINE light.
861504x4joe
52
03-06-2018 12:49 PM
kylekip68
09-25-2005 09:03 PM
sibbles
09-13-2005 09:11 PM
thesilverblade
Aftermarket Products
03-10-2003 08:20 AM
