Master Cylinder - Booster Leak - Ford Truck Enthusiasts Forums
Old 07-19-2013, 04:47 PM
hreyesg's Avatar
hreyesg hreyesg is offline
hreyesg is starting off with a positive reputation.
Hello, Before I get into buying parts like crazy for no reason I would like to ask about this: Couple of days ago while driving downhill coming to a stop and waiting for traffic my brake pedal started to go down to the floor. replaced 2 rear wheel cylinder one was leaking bad 2 months ago.
Noticed as well that between the master cylinder and the power booster brake fluid leaking (picture below) the vacuum hose it's ok not broken or craked
My question: which one should be the problem causing the leak? master cylinder or power booster? and if this will be the cause for the pedal going to the floor.
Thanks !
Old 07-19-2013, 04:49 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Master cylinder.... There should be no oil or brake fluid in the booster.
Old 07-19-2013, 04:52 PM
hreyesg's Avatar
Thanks! I was going to get the power booster, good I asked before
Old 07-19-2013, 05:32 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Get a new booster too while you're at it. The master cylinder will leak into the booster and fill it with brake fluid.
Old 07-19-2013, 06:02 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Smile
Quote:
I agree as long as that has been leaking get both.
Craig
Problems with my brakes please help andrew's64 1967 - 1972 F-100 & Larger F-Series Trucks 9 01-10-2016 06:18 PM
Brake Pedal to the floor. WTH granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-18-2014 08:57 AM
Remote brake booster question GB SISSON 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 03-13-2014 10:12 PM
Brakes Not Releasing fwerring 1997-2006 Expedition & Navigator 1 08-31-2010 04:52 PM
Low Brake Pedal fozzy Brakes, Steering, Suspension, Tires, & Wheels 8 12-10-2006 01:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
