DIFFERENTIAL PINION SEAL - FRONT - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 07-19-2013, 02:34 PM
mig25's Avatar
mig25 mig25 is offline
mig25 is starting off with a positive reputation.
Hello folks, I just want to share some info, about this job, a way to say thank you for the help I get here , is posting good info to help others.
My Expy Eddie 2006 had developed a leak on the front differential seals, both sides as well as the pinion seal ( back ) .
I have replaced the seal on the passenger's side last year, today was time to tacle the pinion seal.
Below is the part number for the seal. It costs $18 at the dealer.
Raise the front of your truck, esnure support with jack stands. Let me just tell you, you will need an air wrench. It will make your job a lot easier.
Also make sure you mark the flange and the shaft so you can put back when it was.
Those 4 bolts on the flage will require a 12MM 12 point socket. Get one at Sears, or autoparts store. Preferably a 1/2 inch . The torque for those 4 bolts is 83 Lbs/ft.
once you remove the bolts grab the shaft and push backwards to separete it from the flange. Make sure the shaft is supported. I used a piece of 4x2 on top of the cross member.
Picture above shows flange in place , note center pinion nut not yet removed.
The above picture shows the flange in place, note I have already removed the big nut on the center it takes a 27 MM socket. You will also need a gear puller to pull the flange out once you have removed the center nut.
Above close up of the flange removed. Below you will now see the seal exposed. It is kind of hard to remove it, be careful not scrape the inside of the differential, I used a small screw driver to remove it.
Here is a close up shot of the old seal in place.
Make sure you lubricate the housing with gear oil before pushing the new seal in . I used a small hammer and a piece of wood to push the new seal in. Be patient. Assemble is in the reverse order.
Old 07-19-2013, 11:10 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Good DIY write-up.
5.4V8 DREADFUL SPARK PLUG ISSUE SOLVED !! mig25 1997-2006 Expedition & Navigator 116 07-21-2016 03:01 PM
FRONT DIFFERENTIAL PART II mig25 1997-2006 Expedition & Navigator 1 07-24-2013 05:34 PM
2006 EXPY EB -WATER PUMP JOB - LOTS OF PICS mig25 1997-2006 Expedition & Navigator 3 03-16-2012 07:45 AM
FRONT DRIVE SHAFT mig25 1997-2006 Expedition & Navigator 2 02-23-2012 08:46 PM
EXPY EDDIE BAUER TRANSMISSION FILTER REPLACE. mig25 1997-2006 Expedition & Navigator 7 01-06-2012 10:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
