3V V10 supercharger - Ford Truck Enthusiasts Forums
3V V10 supercharger
Old 07-18-2013, 11:07 PM
53 Mercury's Avatar
53 Mercury 53 Mercury is offline
53 Mercury is starting off with a positive reputation.
3V V10 supercharger
Check out my gallery for a roots style supercharger on a 3v V10?
Old 07-19-2013, 04:52 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Where are the videos?
Old 07-19-2013, 06:57 PM
53 Mercury's Avatar
I will post videos of Dyno run (tuning session) and track videos next week. Truck gets strapped to the rollers on the 25th and race day on the 26th. It's ran a 12.1 @ 111mph on a bone stock engine with only a set of headers and a 75 shot of nitrous. Truck is a all steel 1953 Mercury M250 mustang II front, 9" 4 link rear, stock 5R110W 5speed and V10 from a 2006 F350. It weights 4620lbs with me in it.
Old 07-26-2013, 11:18 AM
53 Mercury's Avatar
Added some videos and pics to my gallery
Dyno tune day was yesterday truck ran fine but boost wasn't on the agenda! The little M112 roush charger wasn't up to the challenge! I left the stock lower and upper pulley in place for a 5.4L that would make 8psi ... Well on the 6.8L it only made 2psi and only did that after 4000 rpm! We dialed it in with just 2psi and I'll get pulleys in the future to try and squeeze 4psi (if I'm lucky). At the end of the day it looks like I'm gonna have to go with a whip ole 2.3 or larger to feed the extra cubic inches but #'s were 350hp-350tq not exciting by no means but there's no real boost to margin even any extra output- engine load never exceeded 85% whereas if there was any substantial boost it would be over 100%! A good learning experience and with some pulleys should put that # easly over 400 which would equal 500 crank HP! Not bad for low boost, pump gas, 415 ci engine. Another note for v-10 owners .... These things love timing! You can also turn them 6000rpm all day small valves and overhead cams elemiates valve float.
V10 Whipple instructions needed 62bugman 1999 to 2016 Super Duty 7 03-29-2016 01:01 PM
v-10 supercharger advice Jarret1224 Excursion - King of SUVs 18 02-22-2016 07:45 AM
v10 supercharger ford1386 WTB - Parts & other 0 09-15-2015 11:30 AM
Superchargers Watcher58 Excursion - King of SUVs 3 03-22-2015 12:57 AM
2002 F350 V10 with supercharger 98infinity Modular V10 (6.8l) 13 09-25-2013 03:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
